Toymods » Tech & Conversions » gtst vs gtr caliper mounting holes?
V8_MA61
gtst vs gtr caliper mounting holes? Wed, 25 August 2004 11:49 Go to next message
Anyone know if the mounting holes are different between the 324mm style r32 GTR and the 296mm r33 GTST caliper holes are the same distance apart? or, if not..how different are they?
Purely an out of interest question.
ta, blake.
bbaacchhyy
Re: gtst vs gtr caliper mounting holes? Wed, 25 August 2004 21:48 Go to previous messageGo to next message
I think you'll find that the spacing is the same, but the 'legs' are longer to allow for the larger diameter disc.
MB
improvedae86
Re: gtst vs gtr caliper mounting holes? Wed, 25 August 2004 23:03 Go to previous messageGo to next message
S13 ,r32 , r33 , r34 , z32 all use the same caliper bolt pattern when i have come to changing calipers around on s13 hubs . Will look under a r32gtr and double check it against a hub on the weekend . It is 324mm gtr disc you are after ? , another conversion is e36 315mm M3 discs with R32gts calipers with one small s spacer from the upper bolt mount hole to the caliper . Theres a few drawing around the net of that one . Might be cheaper and german discs are way better that crappy brembo discs which you can get aftermarket .
bbaacchhyy
Re: gtst vs gtr caliper mounting holes? Wed, 25 August 2004 23:15 Go to previous messageGo to next message
improvedae86 wrote on Thu, 26 August 2004 09:03
More details man !!
What strut and hub was that with ?
Michael B
improvedae86
Re: gtst vs gtr caliper mounting holes? Wed, 25 August 2004 23:33 Go to previous messageGo to next message
On any Nissan strut with the correct offset of the disc .
Check the Uk Nissan 200sx club web site , SXOC i think . There big time into this conversion due to the E36 m3 discs being cheap as there Sad Maybe not here . You might consider changing the struts to Nissan due to the shorter stroke or the standard strut , less weight , loads about cheap as coilovers , and bigger brakes bolt on . And most importantly a lower roll center without using crappy spacers with add more weight anyway . if you want to keep the Ma61 looking stock you could use the follow which fits in a 15" rim Nissan offset 38' .
R33gts calipers { steel , still light }
or Z32 n/a 300zx calipers { alloy , just watch the bleed nipple }
280MMx32mm z32 n/a Discs { five stud , so will require redrilling } or your might get lucky and find some blanks Smile
V8_MA61
Re: gtst vs gtr caliper mounting holes? Thu, 26 August 2004 00:33 Go to previous messageGo to next message
yeah its the 324/5 mm disc im talking about.
sweet if they have same pattern! Very Happy
Now i just hpoe work doesnt want *too much for them. And lets pray they are the red brembos...i think all 96 gtrs would be?
improvedae86
Re: gtst vs gtr caliper mounting holes? Thu, 26 August 2004 00:36 Go to previous messageGo to next message
bbaacchhyy
Here some r32gts calipers for sale your way , should be $200 for a set .
http://www.nissansilvia.com/forums/index.php?showt opic=48598
V8_MA61
thanks btw guys Smile
bbaacchhyy
Re: gtst vs gtr caliper mounting holes? Thu, 26 August 2004 00:42 Go to previous messageGo to next message
V8_MA61 wrote on Thu, 26 August 2004 10:33
I don't need anymore, I have already completed mine (waiting for the calipers to get powder coated atm) using Scubie WRX discs (the 326mm ones) and 300ZX calipers. Smile
The price for the link is $450 for the set of 4 which is pretty good.
If some Brembo's or JZA80 4 potters come up, I'll grab them as I have a set of HSV AWD Coupe discs (AP Racing radially grooved and vented waiting for a project) that they would fit nicely onto Very Happy
V8_MA61
Re: gtst vs gtr caliper mounting holes? Thu, 26 August 2004 00:45 Go to previous messageGo to next message
see what comes in next month Wink
bbaacchhyy
Re: gtst vs gtr caliper mounting holes? Thu, 26 August 2004 00:57 Go to previous message
V8_MA61 wrote on Thu, 26 August 2004 10:45
I'm standing by to Standby.
Previous Topic:GT4 cutting out - FIXED
Next Topic:Drum to Disc conversion
Current Time: Sat Nov 21 20:45:53 UTC 2026
Total time taken to generate the page: 0.0079019069671631 seconds
