Toymods » Tech & Conversions » Fuel Filters (High/Low Pressure)
takai
Fuel Filters (High/Low Pressure) Wed, 25 August 2004 23:33 Go to next message
Just finalising my fueling setup, and have a little question. Do i put the fuel filter in the low pressure section between tank and lift pump, or should i put it in the high pressure section between the surge tank and the VL-t pump.
I woudl be tending towards the low pressure section, mainly because it will somewhat protect the pump. That and i can use the standard low pressure carby style fittings for it, and the small white plastic filters. Then again, are these good enough for filtering?
improvedae86
Re: Fuel Filters (High/Low Pressure) Thu, 26 August 2004 00:09 Go to previous messageGo to next message
Between tank and pump ? is it lift pump in tanks ? or external ?
Most intank lift pump have a filter , so i guess its external lift pump , so do it the way those standard pumps would work stock :
1. intank outlet line { 6mm }
to
2. fuel filter { carby one is fine for flow i guess its 6mmline }
to
3. surge tank
to
4. VL pump { 8mm ? outlet or 10mm or some models }
to
5. Efi fuel filter { 8mm line ? }
to
6. Overpressured fuel rail {63psi to 73psi vl pressure}, stock pressure regulator { 35-38psi }
to
7. Richly running motor at idle to 4000rpm
to
8. To small return line back to surge tank { need to be the same size as stock vl }
to
9. fuel tank
Well something like that !
Or make the system to the correct pressure returnless
Need to borrow a pipe bender ? Pressure gauge 4age fuel rail fitting for testing ?
Re: Fuel Filters (High/Low Pressure) Thu, 26 August 2004 04:31 Go to previous message
Yeah, a pre-pump low-pressure filter and a post-pump high-pressure filter is ideal. Not strictly necessary but cheap insurance; a small amount of crap in your fuel can kill the pump.
Previous Topic:S54/53 etc etc Where does it say on the box what gearbox it is? (pic)
Next Topic:ta22 custom drop tank...
Current Time: Sat Nov 21 20:03:34 UTC 2026
Total time taken to generate the page: 0.0052790641784668 seconds
