Toymods » Tech & Conversions » 4age 20v putting turbo or 4agze motor please advice
tureuno
Wolli Creek
4age 20v putting turbo or 4agze motor please advice Thu, 26 August 2004 03:49 Go to next message
I'm not sure wether to bolt on a turbo or change my motor to 4age? wgich one would run better?
10sec_rx7
Syndey
Re: 4age 20v putting turbo or 4agze motor please advice Thu, 26 August 2004 03:54 Go to previous messageGo to next message
i have tuned a 4age 20v, it had a small t25 off a early sr20 on it, small intercooler, 1jzgte injectors, microtech LTX8,
made 185rwhp on 6psi boost,
turbo your 20v mate! you wont be dissapointed!
you will find you will have all these people come on here and tell you not to do it it will break etc, dont listen to them, as long as the tune is good it wont break, keep the boost under 10psi and you will be fine,
get a s15 BB t28 for it and you will make easy 210rwhp on 7psi boost.
dale
[Updated on: Thu, 26 August 2004 03:56]
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 4age 20v putting turbo or 4agze motor please advice Thu, 26 August 2004 04:10 Go to previous messageGo to next message
From what I can read off the original post, it looks like he's already got a 4A-GZE. So turbo that. It's heaps stronger internally.
10sec_rx7
Syndey
Re: 4age 20v putting turbo or 4agze motor please advice Thu, 26 August 2004 04:11 Go to previous messageGo to next message
either one loves a turbo
Nark
Cabramatta, NSW
Re: 4age 20v putting turbo or 4agze motor please advice Thu, 26 August 2004 04:17 Go to previous messageGo to next message
The 20V has a MUCH better top end.
But boosting it puts you closer to its limit. So a bad tune could lead to catastrophic events.
10sec_rx7
Syndey
Re: 4age 20v putting turbo or 4agze motor please advice Thu, 26 August 2004 04:20 Go to previous messageGo to next message
bad tune on any turbo motor leads to failures, so its the same as any other turbo motor
drift86levin
brisvegas
Re: 4age 20v putting turbo or 4agze motor please advice Thu, 26 August 2004 04:29 Go to previous messageGo to next message
although thier different part numbers (i think), the 20v rods and crank are the same size and strength as the ZE's, the difference is that the ZE has lower compression pistons, you could help the life of your 20v if you put a slightly thicker head gasket in, just to reduce the static compression abit,
OR
whack in a GZE complete bottom end, bolt the 20v head on the top straight on swap, a few little things here and there.. and turn up the boost!! seen the speed tech corolla? 84' 300kw at the tyres, on the stock bottom end!! AHHHH!!!!!!
[Updated on: Thu, 26 August 2004 05:00]
Flogbag
Sydney (Campbelltown...!)
Re: 4age 20v putting turbo or 4agze motor please advice Sat, 28 August 2004 09:16 Go to previous message
has anyone on here sucessfully put a gze bottom end on a 20v or used gze pistons in a 20v block with 20v crank and rods?????
Previous Topic:4K with 3K head EFI?
Next Topic:AE86 brakes on a KE10
Current Time: Sat Nov 21 08:27:58 UTC 2026
Total time taken to generate the page: 0.0058290958404541 seconds
