Toymods » Tech & Conversions » T18 Diff gone noisey - options?
Gased
T18 Diff gone noisey - options? Thu, 19 September 2002 10:22 Go to next message
On a recent trip from Sydney to Melbourne my T18 diff started to make more noises than usual. I think this started after a little trail of what 150kmh felt like Smile Normally I've only had a bit of crown and pinion noise on deceleration. Now there is a constant whirring noise. I'm too scared now to go on long trips.
Does anyone know what other model centers can swap over? T18s are pretty rare these days and the ones I've seen in the wreckers look like they have seal leakage. I've also been unable to pull out the axle's even with a small pulling hammer - any tips?
What number of splines/diameter of axle?
The front housing on an RA61(?) looks the same. I am also thinking that diffs from auto's would be in better nick in general, but don't know if they have different ratio's? The damn wreckers are taking off the plates with the codes.
What would a diff reconditioner centre actually do and how much would they charge? Any recommendations.
David
Re: T18 Diff gone noisey - options? Thu, 19 September 2002 10:40 Go to previous messageGo to next message
T18's have a T series diff, so you can swap the diff centre from any other car with a T series diff. This includes most RWD Celicas, heaps of Coronas and probably other stuff as well, so you won't have any problem finding one at any old wrecking yard.
Gased
Re: T18 Diff gone noisey - options? Thu, 19 September 2002 14:48 Go to previous messageGo to next message
Thanks Norbie,
I'll go ahead and pull a centre out of an auto celica I've seen. Got to get a hold of an axle puller thingie that goes on the studs. May as well do the wheel bearings as well eh? Never done a diff before.
But what would a diff reconditioner give me over a wrecker part? I guess at $55 for a centre from the wreckers that answers part of the question Smile
David
rob_RA40
c'town, NSW
Re: T18 Diff gone noisey - options? Thu, 19 September 2002 22:58 Go to previous messageGo to next message
be weary of ratios
Gased
Re: T18 Diff gone noisey - options? Fri, 20 September 2002 08:12 Go to previous messageGo to next message
Arrgggh,
a T series but not any T series????
I've looked at some diff comparison charts but haven't found one complete enough for all of the T series.
If I recall right the T18 is a T082 (4.1) emm errr or was it T032 (3.5).....
David
rob_RA40
c'town, NSW
Re: T18 Diff gone noisey - options? Fri, 20 September 2002 09:16 Go to previous messageGo to next message
diff codes
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/AxleCodes.html
Re: T18 Diff gone noisey - options? Fri, 20 September 2002 15:30 Go to previous messageGo to next message
The T292 is the 4.1 ratio, and it's pretty common in T18's, Celicas and Coronas. Probably what you're looking for.
Gased
Re: T18 Diff gone noisey - options? Fri, 20 September 2002 16:21 Go to previous messageGo to next message
Naaaa,
just got home, checked, its a T302 so there!
Yeh, saw the axle code list but without a corresponding model list I'm a bit stuffed.
Why do some/most of the wreckers take off the specs plate when its the VIN plate that would seem to count? Errr I don't suppose they think people will pay for parts without knowing they're the right ones, duhhh?
Anyway 3.5 vs 4.1 is only .6 so who cares Razz
David
Re: T18 Diff gone noisey - options? Sun, 22 September 2002 01:41 Go to previous messageGo to next message
Only .6? That's a pretty big difference actually.
Re: T18 Diff gone noisey - options? Sun, 22 September 2002 02:58 Go to previous messageGo to next message
In theory its not much! But in real life that a huge differnece Shocked
Gased
Re: T18 Diff gone noisey - options? Sun, 22 September 2002 15:03 Go to previous messageGo to next message
Gents,
what's the diff code for RA40 & RA61's? Auto vs man?
David
rob_RA40
c'town, NSW
Re: T18 Diff gone noisey - options? Sun, 22 September 2002 23:48 Go to previous messageGo to next message
RA40 man - T292
RA60 man - T312
Gased
Re: T18 Diff gone noisey - options? Mon, 23 September 2002 09:52 Go to previous messageGo to next message
Thanks Rob,
I really appreciate the help, you must have a better diff chart than I do.
I've got 3.727:1 and the RA40 is 4.1 and RA60 is 3.909
Get one of each and suck and see! Razz
My diff is a 'taller' ratio i.e., less revs of engine for 1 rotation of wheel.
If I upgrade to a 3T-GTEU and W58 which ratio is best????
Can anyone point me to a dummies guide to gear ratio/diff ratio/torgue /engine matching?Confused
David
rob_RA40
c'town, NSW
Re: T18 Diff gone noisey - options? Mon, 23 September 2002 10:17 Go to previous messageGo to next message
i used that link posted up there
_T_29_2_
T is series 6.7".
29 is ratio.
2 is 2 pinion non lsd.
the 3.7 wouldnt be too bad with the 3T-GTE, as for what ratio u should decide on depending on power and torque, i cant help u there, but i can say that ive had the 4.1 and the 3.9 behind my 1G-GE, i didnt notice any rev difference at 110kmp/h, nor notice any drop in acceleration, but i did notice that with the 3.9 it was much nicer to drive in traffic...
dunno if that helps your decision but i thought id post it anyways..
Gased
Re: T18 Diff gone noisey - options? Mon, 23 September 2002 12:54 Go to previous message
Thanks,
yeh saw that. But models! What models have what diffs!
OK, I took a punt cos I saw T series in RA 40/60 but there are other models?
Got that too. The chances of an LSD centre are like zilch, zero, diddly squat. I like the idea of replacing my crunchy centre for $55 vs $700.
>the 3.7 wouldnt be too bad with the 3T-GTE......
yeh more power/torque steeper ratio.
So if I could find an exact replacement T302 (3.7) I'd be better off - so here goes a post on parts wanted - cos all the T18 diffs I've seen in wreckers are stuffed just like mine.
Interesting about.....
>but i can say that ive had the 4.1 and the 3.9 behind my 1G-GE, i didnt >notice any rev difference at 110kmp/h, nor notice any drop in >acceleration, but i did notice that with the 3.9 it was much nicer to >drive in traffic...
Not drop in acceleration but where was the 'powerband' - with 4.1
I would expect you'd be reving higher (above powerband) for equivalent acceleration? How does a 1G-GE compare to a 3T-GT??
Again thanks for the info
David
Previous Topic:max boost on 7MGTE
Next Topic:fitting RX7 S4 brakes to sprinter
Current Time: Mon Oct 26 08:41:25 UTC 2026
Total time taken to generate the page: 0.005842924118042 seconds
