Toymods » Tech & Conversions » sa 63 bellhousings
cambelt
melb
sa 63 bellhousings Thu, 26 August 2004 14:49 Go to next message
i have a 2s sa63 bellhousing , deffinate because i pulled it out of the car, ive seen a pic of another bellhousing off a diesel engine toyota that is just about identcal 2 it , is that the 2c diesel 1 , is there any better reason for using the diesel 1.
Jayem
Finland
Re: sa 63 bellhousings Thu, 26 August 2004 15:43 Go to previous messageGo to next message
The diesel one is from 1C and it's exactly the same as 2s one.
[Updated on: Thu, 26 August 2004 15:44]
cambelt
melb
Re: sa 63 bellhousings Fri, 27 August 2004 15:12 Go to previous messageGo to next message
Thank you for your reply, ill try 2 get hold of it.
CLG
Perth, Western Australia
Re: sa 63 bellhousings Sat, 28 August 2004 04:31 Go to previous messageGo to next message
The C series bellhousing also has the starter motor snout on the RHs of the bellhousing, away from the exhaust manifold!
Anthony Kellam
Re: sa 63 bellhousings Sun, 29 August 2004 03:37 Go to previous messageGo to next message
Does the 1C bell put the motor upright? I heard that 3Y/4Y bells fitted on to 3SGTE's if you moved one of the bell houing bolts 20mm. This bell also puts the motor upright apparently. Just trying to track one down.
Perhaps these are the starting point for the bell housings ppl bring in from across the tasman?
CLG
Re: sa 63 bellhousings Sun, 29 August 2004 05:10 Go to previous messageGo to next message
Both the S and C series bellhousing put the engine in a vertical postion.
Re: sa 63 bellhousings Sun, 29 August 2004 10:18 Go to previous messageGo to next message
What he said below Very Happy
I have both bellhousings and have tried them on all gen turbo blocks, and they both make the engine sit on an angle compared to the gearbox.
[Updated on: Sun, 29 August 2004 10:36]
CLG
Re: sa 63 bellhousings Sun, 29 August 2004 10:21 Go to previous message
I've seen both and used them, though I did also use a non turbo block for the mounting positions?
[Updated on: Sun, 29 August 2004 10:27]
Previous Topic:1ggte front pulley swap with...??
Next Topic:RWD 4ag dizzy cap
Current Time: Fri Oct 23 04:53:37 UTC 2026
Total time taken to generate the page: 0.043288946151733 seconds
