Toymods » Tech & Conversions » Makeshift map sensor
davedave
Makeshift map sensor Fri, 27 August 2004 00:26
In looking for a map sensor for a gen2 3sgte (AFM), I had this reply.
This sounds pretty good, and negates the need for a FCD too.
From the mr2 board:
http://www.mr2oc.com/newreply.php?s=&action=ne wreply&postid=422533
Quote:
posted by JimKing
Quote:
posted by Driftin_AW
sweet so all you need is a resistor. Just need to find what resistance the stock one has around 0psi and get one to suit, or get a variable resistor and turn it until the computer doesnt' start in limp mode, but not so far that you get boost cut constantly.
To carry off this deception, you probably want to use a resistor "bridge". You use two resistors in series wired between ground and the +5v MAP sensor supply. You connect the MAP signal wire to the junction between the two resistors. The junction voltage is proportional to the resistances.
Vj = R2 / (R1 + R2) * 5.0v, assuming R2 is connected to the 5v supply, and R1 is connected to GND.
A two bar map sensor should read about 2.5v at 0.0psi, so if you want to simulate that, then a couple 10k ohm resistors should do.
See if this artwork helps:
.........R1.....................R2
..|-\/\/\/\/\-O-/\/\/\/\/-|
.GND...............Vj...................+5V
............(to ECU PIM input)
Previous Topic:Auto RT104 -> 5sp with RA60 bits?
Next Topic:restoring aloy wheels
Current Time: Sat Oct 31 18:46:10 UTC 2026
Total time taken to generate the page: 0.019073009490967 seconds
