Toymods » Tech & Conversions » GZE Sensor on the back of Inlet Manifold
takai
GZE Sensor on the back of Inlet Manifold Fri, 27 August 2004 09:08 Go to next message
Does anyone know what this sensor is? Its located on the back of the inlet manifold, near where the throttle bolts on. Post supercharger though.
Somewhere along the line the one on mine has gotten cracked, and im not sure how. Nor am i sure even what it does.
drift86levin
brisvegas
Re: GZE Sensor on the back of Inlet Manifold Fri, 27 August 2004 09:21 Go to previous messageGo to next message
i know what your talking about as i was in that general area this morning! and thinking the same thing!
sideshow
Re: GZE Sensor on the back of Inlet Manifold Fri, 27 August 2004 11:29 Go to previous messageGo to next message
if its a grey plug round with 2 wires its the air temp sensor
has one brown wire and black i think
takai
Re: GZE Sensor on the back of Inlet Manifold Fri, 27 August 2004 11:35 Go to previous message
Ah ok, and im guessing a damaged one would fluctuate readings quite badly?
EDIT: Im guessing it probably wouldnt be causing symptoms like not being able to set timing, and the MAP sensor hunting for vacuum. I think i also have a vac leak somewhere in there, and am going to try and find that tomorrow.
[Updated on: Fri, 27 August 2004 11:56]
Previous Topic:Would a 5ME engine fit into a corona
Next Topic:cold air intake ke70
Current Time: Sat Oct 31 09:27:48 UTC 2026
Total time taken to generate the page: 0.0098440647125244 seconds
