Toymods » Tech & Conversions » rwd evo engine????
scubba
rwd evo engine???? Fri, 27 August 2004 11:30 Go to next message
hey all my mate just got an old skool GALANT 1971 i no its not a toyota BUT these this can be tuff we r just wondering if its possible to make the mitsubishi 4G63B motor into a rwd coz we r not quite sure if there is a gearbox and other mods avaliable just want to no if anyone has any idea cheers (ohh yer we tried most of the evo clubs and some of em dont even have proper forums
any help anyone???
GO THE KE20'S 4AGTE powered
V8_MA61
Re: rwd evo engine???? Fri, 27 August 2004 11:37 Go to previous messageGo to next message
its possible with a lot of $
All new manifolds, everything - you need to start from scratch.
Are these the same as a gtr and have the front diff centre out the side of the sump?
if so, i dont like your chances.
Re: rwd evo engine???? Fri, 27 August 2004 13:12 Go to previous messageGo to next message
I gather it's doable using the Jap 5 speed Sigma box/maybe even a Starion box. Obviously manifolds would be an issue. You probably need to try and find a bloke called Steve Knight, at least he used to be well known for pulling tricks like this.
frr33q
Re: rwd evo engine???? Sun, 29 August 2004 01:01 Go to previous messageGo to next message
i had a mate that had a VR4 motor in a GSR Sigma! so im assuming that its doable, i dont see why not. the only prob would be that u need lots of custom fabrications and finding a gearbox to fit might also be difficult Smile man anything is possible with the right amount of money Very Happy
fatmr2
Re: rwd evo engine???? Sun, 29 August 2004 05:38 Go to previous messageGo to next message
it wont be as hard as a lot of people make it out to be. Depending on which box you use you will need a custom bell housing. and you will also need to modify the water pipe that comes out of the head as it will be at the back if you make it rwd. A few people have put these engines in rwd's. A quick example would be that green dato ute at the drags that has a vr4 motor in it.
Just dont beleive everything people tell you and ask a few of the work shops out there about what needs to be done.
Good luck with it all.
bubbles
Banned user
Liverpool NSW
Re: rwd evo engine???? Sun, 29 August 2004 07:15 Go to previous messageGo to next message
the last model of the starion(pumped out guards), came with a 2.7turbo(same block has the vans, cheap from korea)just get that half cut with the gearbox. Its problably cheaper, has a friend of mine (aussie starion) found that out too late.
floody
Re: rwd evo engine???? Sun, 29 August 2004 10:22 Go to previous messageGo to next message
Some (not all) Evo motors rotate backwards - like a VTEC Honda. So unless you want a car with 1 forward gear and 5 really fast reverse gears, a VR4 motor would be better.
VR4+starion box I would say. Still will be a lot of hassles.
I'd just turbo + inject a 2.6 sigma motor with custom manifolds, ecu etc.
Re: rwd evo engine???? Sun, 29 August 2004 11:13 Go to previous messageGo to next message
see here for more useful things to do to galants ..
<http://www.cordiapower.com/forum/index.php>
bubbles
Banned user
Liverpool NSW
Re: rwd evo engine???? Sun, 29 August 2004 22:57 Go to previous messageGo to next message
clubvr4.org
scubba
Re: rwd evo engine???? Mon, 30 August 2004 03:10 Go to previous message
cheers ppls just really wanna get this galant going and going good all the info has been great help
Previous Topic:Sprinter tacho with 1ggte
Next Topic:1ggte RA28 G-box X-member
Current Time: Thu Oct 22 13:37:08 UTC 2026
Total time taken to generate the page: 0.017940044403076 seconds
