Toymods » Tech & Conversions » stainless headgaskets? any good?
nizchic
queensland
stainless headgaskets? any good? Fri, 27 August 2004 13:15 Go to next message
i have an engine being balanced etc. by a reputable machine shop at the moment, on the subject of using a 2mm stainless head gasket they have said to use copper instead? the blocks not o-ringed (yet) is the stainless going to work? any ideas...
Toobs
Re: stainless headgaskets? any good? Fri, 27 August 2004 14:46 Go to previous messageGo to next message
I haven't heard of a stainless head gasket before.
I assume that if it was solid stainless steel that it would not be maleable enough to seal properly.
Copper is quite maleable and seems to be the norm as far as metal head gaskets go
nizchic
queensland
Re: stainless headgaskets? any good? Fri, 27 August 2004 22:53 Go to previous messageGo to next message
i did a search on this forum to see if any one had already talked about it. copper no good apparently?
olihaub
Re: stainless headgaskets? any good? Sat, 28 August 2004 04:53 Go to previous messageGo to next message
from my experience copper is good only for really big power projects and if u want to lower the compression (ie: tripleplate gasket of copper)
i agree with toobs
stainless steel wouldnt work and i wouldnt try it
i think someone was smoking something a lil strange when they told u that
um also wot sort of power are you looking at because if u get the tuning right and ur car doesnt do a 400m pass under 11sec with 500kw at the rear wheels i dont see why u would need one
but wot motor is it and wot set up r u hooking up cos u might not need a copper one at all
ive heard from a mate who used to work a Crydon that the mentallity there is that if u get the car tuned right u shouldnt need anything but a standard head gasket unless u need to lower the compression
anyways as always i could be totally wrong thats just wot have been led to believe so feel free to correct me anyone Very Happy
Toobs
Re: stainless headgaskets? any good? Sat, 28 August 2004 07:20 Go to previous messageGo to next message
Stainless "may" be used as part of a multi layer steel (MLS) head gasket... Nobody seems to say what steel they use in an MLS gasket though so it could be any sort of steel.
I doubt very much that stainless would work well as a solid 2mm head gasket like you have described though due to the points I already raised.
nizchic
queensland
Re: stainless headgaskets? any good? Sat, 28 August 2004 10:27 Go to previous messageGo to next message
We can get stainless head gaskets from Advan in a range of thicknesses. they tell me there a TRD product. apparently they can weep a little around the oil feed if you dont bond it properly. that happened to a friend with an mr2
Re: stainless headgaskets? any good? Sat, 28 August 2004 10:30 Go to previous messageGo to next message
The gen3 3S has a multilayer stainless gasket from the factory.
nizchic
queensland
Re: stainless headgaskets? any good? Sat, 28 August 2004 10:39 Go to previous messageGo to next message
do you think 2mmis too thick? i have bought forged pistons
Toobs
Re: stainless headgaskets? any good? Sun, 29 August 2004 12:59 Go to previous messageGo to next message
2mm is probably a bit thick if you haven't had much machining done on the contact surfaces.
AFAIK the main reason they make larger thicknesses like 2mm is to compensate for any extra metal taken off the block or head to remove imperfections.
Some people use thicker head gaskets to lower compression a little, however, I think using thicker gaskets for this reason is a stupid idea!
rokusan
western queensland
Re: stainless headgaskets? any good? Tue, 28 September 2004 09:36 Go to previous messageGo to next message
ok thanks for all the info, havehad block O ringed and made a 80 thou copper headgasket.
rokusan
western queensland
Re: stainless headgaskets? any good? Thu, 06 January 2005 08:11 Go to previous messageGo to next message
copper headgsket got canned as i took my engine off the builder before he O-ringed it, so i've got stocko gen2 in the kit but i was thinking 205 metal for $117 from toyota.
what about TRD? can i order them from toyota?? which one is the goods? how much have you paid for em? ta guys for putting up with me Razz
Toobs
Re: stainless headgaskets? any good? Thu, 06 January 2005 09:02 Go to previous message
TRD 0.8mm MLS Headgasket seems to be the most commonly used HG thickness... give you enough room for a slight shave of the block.
About $180ish from Toyota if I remember correctly.
Previous Topic:Air con compressor replacement
Next Topic:auto wiring ae82
Current Time: Fri Nov 20 12:37:10 UTC 2026
Total time taken to generate the page: 0.0071890354156494 seconds
