Toymods » Tech & Conversions » Thinnest thermo fan available?
Farmsci ST162
Thinnest thermo fan available? Sat, 28 August 2004 04:28 Go to next message
can anyone tell me what the thinnest thermo fan available is? i have a space no wider than 3cm in which to put my thermo fan, otherwise i guess ill have to get a small one and mount it at the front blowing through.
indigoid
Canberra, ACT
Re: Thinnest thermo fan available? Sat, 28 August 2004 09:39 Go to previous messageGo to next message
Our KE26 has a Davies Craig thermofan in it that I picked up at Supercheap. I haven't measured it, but it's no more than 3 or 4cm deep. It is intended to be mounted in front of the radiator though. Mounting bits weren't difficult; just bought a big strip of 25x3mm steel from a scrap yard ($2 or so), drilled holes in it, and cut it up with a hacksaw. It all seems to work well.
Total cost was easily under $100 including the separate thermoswitch unit, fuse, and wiring, don't remember the final figure though.
ra23celica
Re: Thinnest thermo fan available? Sat, 28 August 2004 09:50 Go to previous messageGo to next message
I think the thinnest Davies Craig do is 38mm but I could well be wrong.
And - don't just use metal plate as washers for the bolts/nuts that mount the fan, you will conduct uber heat into the plastic mounting clips and retaining nuts. Get and use some fibre washers and put those between the rad fins and the bolt.
No point in getting towards the end of a good conversion and then cutting corners with the small things!
Mitch.
indigoid
Canberra, ACT
Re: Thinnest thermo fan available? Sat, 28 August 2004 09:59 Go to previous messageGo to next message
meh, it (the plastic) doesn't get hot at all, even after sitting stationary for a while (in my car, anyway)
you have a valid point of course
[Updated on: Sat, 28 August 2004 10:01]
Farmsci ST162
Re: Thinnest thermo fan available? Sat, 28 August 2004 12:09 Go to previous messageGo to next message
38mm hey... well i guess ill forget about mounting behind the radiator, ill have to check clearance behind the air con gear at the front and mount it there. maybe a bonnet vent to keep under bonnet temp in check also.
thanks guys.
ra23celica
Re: Thinnest thermo fan available? Sat, 28 August 2004 12:17 Go to previous messageGo to next message
I had better clarify that to say what I meant to say. That you should get some fibre washers between the rad fins and the metal washers/plates, not just use fibre washers instead of the metal plates, or just the metal plates by themselves. Give your fan mounting points a little more protection and maybe not crush as many rad cooling fans by using just metal weashers alone.
Mitch.
indigoid
Canberra, ACT
Re: Thinnest thermo fan available? Sun, 29 August 2004 04:40 Go to previous messageGo to next message
Perhaps i should clarify... the steel brackets I made up don't mount to the radiator at all; they attach via four bolts to the radiator support panel. The fan is still fairly close to the radiator, however. If I notice it getting too hot, or vibrating too much, I'll look at getting some nonmetallic washers
V8_MA61
Re: Thinnest thermo fan available? Sun, 29 August 2004 05:14 Go to previous messageGo to next message
38mm fan?! holy crap...that is thin!
I have a thin one off a diahatsu charade, and its a 10" prob 50mm deep...it blows craploads of air! I upgraded the ma70 cooling system with the use of this as the aricon fan. My alternator doesnt like it when the 2 big cooling fans and the ac one are on all at once! Laughing
ra23celica
Re: Thinnest thermo fan available? Mon, 30 August 2004 01:05 Go to previous messageGo to next message
My bad......I just Googled Davies Craig and the thinest I could fine is 50mm, I must have been thinking of a standard fan I found on a car at a wreckers, but I can't remember the make and model now.
My apologies.
Mitch.
Farmsci ST162
Re: Thinnest thermo fan available? Mon, 30 August 2004 03:29 Go to previous message
i guess ill go see what the wreckers have on offer this weekend
Previous Topic:'99 corolla help
Next Topic:TA22 Boss Kit
Current Time: Tue Oct 20 12:49:13 UTC 2026
Total time taken to generate the page: 0.022707939147949 seconds
