Toymods » Tech & Conversions » Sprinter tacho with 1ggte
Dirty_Sanchez
icon7.gif  Sprinter tacho with 1ggte Sat, 28 August 2004 09:03 Go to next message
Hi, i have a sprinter with a 1ggte in it and i'd like to get the old tacho to work with the engine properly. I have no idea what i'd need to do to get it working so any advice would be very awesome. I have already done a search on the forums but i wasn't able to find and info relevant to what i need. Thanks.
CrAiGzEE
south of the big smoke
Re: Sprinter tacho with 1ggte Sat, 28 August 2004 13:46 Go to previous messageGo to next message
look up a shop in the yellow pages that specialises in instruments (not music) take ya cluster down, hand him about $60 take it home plug it back in and walllar!
JAZE
cronulla
Re: Sprinter tacho with 1ggte Sat, 28 August 2004 14:12 Go to previous messageGo to next message
I just read what i wrote, it was late , im a complete doofus, appologies are in order, refer to pm. I get a slip up now and then.....
[Updated on: Sun, 29 August 2004 17:20]
Re: Sprinter tacho with 1ggte Sat, 28 August 2004 14:17 Go to previous messageGo to next message
JAZE wrote on Sun, 29 August 2004 00:12
if the motor is from a soarer (1G) it will have an electric speedo drive of the box, and you can not make that work with the sprinter cluster, If it is a supra motor it should have a speedo cable from the box which you can possibly calibrate/adjust to fit in the back of the sprinter cluster, If you have he electric cable remove it and go and buy the speedo cable(non electric) from any w5X box and put it in the same place where the electric one is, and then go from there with putting it into the sprinter cluster.
ps. cool name..............
Tacho Very Happy
JAZE
cronulla
Re: Sprinter tacho with 1ggte Sat, 28 August 2004 14:40 Go to previous messageGo to next message
.... sorry for wasted space. Embarassed
[Updated on: Sun, 29 August 2004 17:25]
Re: Sprinter tacho with 1ggte Sat, 28 August 2004 14:46 Go to previous messageGo to next message
Very Happy
[Updated on: Mon, 30 August 2004 03:48]
RA28
Re: Sprinter tacho with 1ggte Sat, 28 August 2004 15:03 Go to previous messageGo to next message
You can mod your own tacho easy enough, at least I did in my RA28, should be the same deal, you just need a tacho (or something simmilar to mod it off...(or you can just take a bit of a guess and wind it back so it reads 2/3 of what it said originally. PM me if you're interest and I'll dig up the pictures.
Tim.
SeptemberSquallIndustries
Re: Sprinter tacho with 1ggte Sat, 28 August 2004 15:21 Go to previous messageGo to next message
The forums are going to shit.
Re: Sprinter tacho with 1ggte Sat, 28 August 2004 15:44 Go to previous messageGo to next message
SeptemberSquallIndustries wrote on Sun, 29 August 2004 01:21
Agreed
Dirty_Sanchez
Re: Sprinter tacho with 1ggte Sun, 29 August 2004 01:37 Go to previous messageGo to next message
thanks for the help guys, much apprieciated. It was the rev part of the guages that i want working (if there was any confusion). Gonna pull it apart and see what i can do with it.
Anthony Kellam
Re: Sprinter tacho with 1ggte Sun, 29 August 2004 03:32 Go to previous messageGo to next message
It should be easy enough to get it working as 1G's have a single coil.
You have probably tried connecting your AE86 tacho to the TAC output of the igniter module? This works on some igniters but not others. The 86 tacho is expecting a "spikey negative pulse" from the coil negative as it was designed to run with old school points ignition on the 4A-C.
If you just connect the tacho wire directly to the negative of your coil it will start working. Smile easy....
ae86drift
sydney.au
Re: Sprinter tacho with 1ggte Sun, 29 August 2004 05:39 Go to previous messageGo to next message
Anthony Kellam wrote on Sun, 29 August 2004 13:32
ahh the master returneth
Bugman
Re: Sprinter tacho with 1ggte Sun, 29 August 2004 08:35 Go to previous messageGo to next message
yeah but it wont be accurate as the 1g is a 6 pulses per rev where as the 4a was 4 pulses
RA28
Re: Sprinter tacho with 1ggte Sun, 29 August 2004 09:01 Go to previous messageGo to next message
Yeah but you can adjust the tacho to accept the 6cyl engine. I did on an RA28 anyway.
Tim
Bugman
Re: Sprinter tacho with 1ggte Sun, 29 August 2004 10:20 Go to previous messageGo to next message
yeah the 28s have adjust pots on them. you could either do it yourself or get a workshop to do it accurately. but I'm unsure about the sprinter guage as I knonw my rt142 corona guage lacks these pots.
Anthony Kellam
Re: Sprinter tacho with 1ggte Sun, 29 August 2004 11:47 Go to previous messageGo to next message
Oh so you didn't just want it working, you want it accurate as well?? Razz
AE86 ones do not have the potentiometer. They are calibrated via adjusting the magnet spacing on the meter movement (you should see a grub screw with locknut secured with some green goo).
Alternatively there is a resistor swap for the small PCB in the tacho involving two resistor changes. I'll try and find it...
BTW, it's 3 pulses per rev versus 2 Wink
Dirty_Sanchez
Re: Sprinter tacho with 1ggte Sun, 29 August 2004 23:46 Go to previous messageGo to next message
ahh thanks, i would like it to be accurate. I've got the ECU hand unit to tell me what the rev's are, but i'd much rather the existing tacho telling me the rev's.
CrAiGzEE
Re: Sprinter tacho with 1ggte Mon, 30 August 2004 00:34 Go to previous messageGo to next message
/me points to his first post!
AE86slut
Baulko Hillo
Re: Sprinter tacho with 1ggte Mon, 30 August 2004 03:12 Go to previous message
I would suggest you send Sideshow a PM..... He attached a little gizmo to my tacho input so it would work with the quad-coil setup. (I know it's a 4, not a 6, but he could still give you some direction.)
Previous Topic:oil catch can hose type?
Next Topic:rwd evo engine????
Current Time: Fri Oct 23 15:15:36 UTC 2026
Total time taken to generate the page: 0.0058832168579102 seconds
