Toymods » Tech & Conversions » 1ggte RA28 G-box X-member
Snyper
1ggte RA28 G-box X-member Sun, 29 August 2004 06:02 Go to next message
just put my 1ggte into my RA28, originally the RA28 was auto but the manual conversion has been done to suit the new engine, does anyone know a direct fit for the gearbox x-member? other celica ones fit ?! or just make a custom one like we did last time ?!
Brendon
CrAiGzEE
south of the big smoke
Re: 1ggte RA28 G-box X-member Sun, 29 August 2004 07:43 Go to previous messageGo to next message
custom AFAIK
Fattony
Re: 1ggte RA28 G-box X-member Sun, 29 August 2004 08:24 Go to previous messageGo to next message
With a bit of 50x50 angle and a drill you can make it fit
Snyper
Re: 1ggte RA28 G-box X-member Sun, 29 August 2004 11:08 Go to previous messageGo to next message
yeah, last one we made was just 2 pieces of angle iron, tubular steel and a plate for the g-box to sit on...
Brendon
ra23celica
Re: 1ggte RA28 G-box X-member Mon, 30 August 2004 00:44 Go to previous message
Its a custom job for sure.
The W57 behind my 1G-GZE in my RA23 used two orginal holes of the 4 total on the g/box cross member.
I had 2 pieces of 3mm steel welded on each side of the old W50 bracket and two new holes cut. I also had a 3mm plate welded inside the bracket to lift the g/box back up by this amount; as the 3mm steel mounting bracket 'extensions' lowered it by that amount and I was keen to keep the angle to the driveshaft yoke the same as the factory tolerance.
If this does not make any sense, PM me with your mobile phone number and I will call you and explain it further.
Mitch.
Previous Topic:rwd evo engine????
Next Topic:Biggest motor in a TA-22?
Current Time: Fri Oct 23 02:57:57 UTC 2026
Total time taken to generate the page: 0.0035490989685059 seconds
