Toymods » Tech & Conversions » help!!! starter motor i think!
troyboy
Colyton, NSW
help!!! starter motor i think! Thu, 23 May 2002 07:39 Go to next message
Help... I need a starter motor Sad
for a 4agze ... is it the same as a 4age ???
Oh my God i am sooo over my car!
All it does is 1 click on each turn of the key ... had to clutch start it...
while running turned key and nothing...
so i am assuming this is the problem....
help please!
thanx in advance
troyboy
Colyton, NSW
Re: help!!! starter motor i think! Thu, 23 May 2002 08:23 Go to previous messageGo to next message
surely someone can help!!!!
my car is stuck at work in a car park.. no road side...
ahhhhh!
i finish at 1am... noooo
isthere anything !???
Re: help!!! starter motor i think! Thu, 23 May 2002 08:38 Go to previous messageGo to next message
I'm pretty sure the 4agze starter is the same as the 4age!
If you have a multimeter you can measure the volts on the starters solenoid. You'll need 2 people to do this. Get someone to engage the starter and then measure the volts on the starters solenoid.
Alternatively you can get a jumper lead and put it on the positive terminal of the battery and put the other end to the terminal of the starters solenoid! If that works you've got problems with the ignition!
Darola
Taree, 4h nth of syd
Re: help!!! starter motor i think! Thu, 23 May 2002 12:15 Go to previous messageGo to next message
if your running the 4agze lsd gearbox then i think there different starter motors, if its only doing one click, check the battery, if u have nothing to check it with, turn the headlights on and highbeam, then try and start it, if the lights dim lots then i think the battery is flat
normally if its the starter motor it will click more
also if it is the starter, hit it with a hammer or a metal pole on the starter and that works sometimes, make sure u hit the solinoid tho, dont bash it, just hit it alittle
Darola
troyboy
Colyton, NSW
Re: help!!! starter motor i think! Thu, 23 May 2002 13:28 Go to previous messageGo to next message
i cant find the starter motor!
help!!!
whiteGZE
Western Sydney
Re: help!!! starter motor i think! Thu, 23 May 2002 14:36 Go to previous messageGo to next message
ARGH Troyboy
The starter motors for a 4age and 4agze are different. The 4agze starter motor has a different gearing, though you may still be able to bolt in a 4age one in.
Yeah try giving it a bit of a tap. The starter motor is located under the intake manifold, at the back of the engine, firewall side.
faulksy
Re: help!!! starter motor i think! Thu, 23 May 2002 14:58 Go to previous messageGo to next message
Im sure if they are not the same, they are interchangeable. When i change motor fom a 4age to a 4agze there was no change in starter motor
troyboy
Colyton, NSW
Re: help!!! starter motor i think! Thu, 23 May 2002 15:59 Go to previous messageGo to next message
thanx guys!
got it working..
clutch start...
AND DROVE OUROUNTHE CAR PARK..
got back turned off.. turn on.. hey presto!
hmmmm!
faulksy
Re: help!!! starter motor i think! Thu, 23 May 2002 16:49 Go to previous messageGo to next message
Just dont park facing uphill Very Happy
St3ve_AE92
South of Wollongong
Re: help!!! starter motor i think! Sun, 26 May 2002 13:15 Go to previous message
Yeah, i had this same prob with my car when i first bought it.
If would start sometimes, but others it would just make a click click click noise. really annoying. i had to clutch it quite a few times till it got fixed. i think all the mechanic did was gave me a new battery. starter motor was alright.
battery cost me $80. not to mention the other $400 i had to spend on that service.....Sad
ahh well, its alright, she's running good now. except for the gearbox..which they didn't look at. makes a crunch when chaning back down gears. synchros or something? what yas reckon? before i asked, got suggestions like change gearbox fluid..
sorry to take over the thread... :/
Previous Topic:Wheels in above pictures
Next Topic:How much does it cost for a HKS MHG in Australia?
Current Time: Wed Oct 21 14:46:24 UTC 2026
Total time taken to generate the page: 0.053325891494751 seconds
