Toymods » Tech & Conversions » 18R - what's this?
7M-Brisbane
18R - what's this? Sun, 29 August 2004 12:19 Go to next message
Heyyas
I bought an 18R carby & manifold for my RT104 Corona today, but it came off an RA28 Celica. When I bolted it up, I noticed that it didn't cover this hole - which from memory didn't exist on the RA28 head. I assume it is something to do with pollution gear, but if anyone knows where it goes, I'd be interested to know.
I also want to know what models of carby 18R heads came WITHOUT this hole as I now need to get one of these Mad
Leigh
http://www.turbosupras.com/~lmdwyer/RT104/18R%20Head.jpg
Jonny2TG
Tasmania
Re: 18R - what's this? Sun, 29 August 2004 12:26 Go to previous messageGo to next message
Without having a good look at it, my best guess is its a EGR port. (Exhaust Gas Recirculation). Some exhaust gas goes through a metal pipe, controled by a big diaphram, then back in the intake manifold. The exhaust gas is used as a inert gas, which lowers combustion temperature which reduces a cirtain toxic gas in the exhaust.
You don't need it. Weld up the hole.
7M-Brisbane
Re: 18R - what's this? Sun, 29 August 2004 12:40 Go to previous messageGo to next message
Exactly as I thought, just amazed that Toyota had two different head castings.
I know I don't need the hole, but where does it go? A bit sketchy about welding it up as (a) I have to disassemble and clean the head to do it and (b) the chance of welding splash on wherever the hole actually goes is no doubt pretty high!
Does anyone know what models did/didn't come with this?
people100
Rocklea qld
is say just get a manifold that covers it if possible. rather then risking damage by welding it up. BTW nice pic of my commodore boot hey.
Re: 18R - what's this? Sun, 29 August 2004 13:08 Go to previous messageGo to next message
i think that hole is in the 18RC heads only - earlier 18R only used used exhaust gases to heat the choke up and heat the manifold 'plenum' under the carbi.
mine has this hole blocked up with a threaded rod with hex socket pressed into it. once attached, it has been ignored ever since.
it originally went to an EGR valve mounted on the manifold, or if you were really lucky, to egr valve attached to a flange below the carb.
18RC only major improvement was a better upper cam chain tensioner (spring plus oil pressure instead of just a spring) ... i think. heads are similar - maybe compression is different for the emissions model.
advice: find any bolt that fits it, attach said bolt, then forget.
M.W.P.
Rocky Mountains, Canada
Re: 18R - what's this? Sun, 29 August 2004 15:25 Go to previous messageGo to next message
What thechuckster said...
Its for the EGR on the 18RC, the 18R didnt have it.
Plug it up.
7M-Brisbane
Re: 18R - what's this? Mon, 30 August 2004 10:46 Go to previous message
Yeah, as MWP said I think I'm just going to plug it up... I had wanted to pull the head off and have a bit of a look-see in the engine (unknown condition) but I guess if I can get away without it I might as well. Will look at a welsh plug... or else tap & bolt it.
[Updated on: Mon, 30 August 2004 10:55]
Previous Topic:1G-GTE RA60s
Next Topic:18RG valve recession {not the seats}
Current Time: Sat Oct 24 09:09:58 UTC 2026
Total time taken to generate the page: 0.0041358470916748 seconds
