Toymods » Tech & Conversions » help needed with hilux 74
muli
help needed with hilux 74 Sun, 29 August 2004 21:32 Go to next message
could someone tell me what engine a 1974 toyota hilux has, all i know it is 1.6l but what type of engine, someone told me they share the same engine as the early 70's 1600cc celica´s?
Also what about engine transplants, what would be the most ideal option? A bit more power would be nice
[Updated on: Mon, 30 August 2004 08:58]
muli
Re: help needed with hilux 74 Wed, 01 September 2004 08:39 Go to previous messageGo to next message
i just looked under the bonnet and the engine is 12R, anyone got any info on this little engine?
Re: help needed with hilux 74 Wed, 01 September 2004 08:56 Go to previous messageGo to next message
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/GasolineEngines.html
Any R motor should fit.
schnitzel
Bendigo
Re: help needed with hilux 74 Wed, 01 September 2004 09:17 Go to previous messageGo to next message
It is a 12r motor as found in early Hilux, Hiace corona and daihatsu 4wd vehicles. Can be interchanged with 2r but why would you.
18r motors do not interchange without changing gearbox as well and modifying engine mounts although this not a difficult conversion.Would also need to change diff centre.
If you want more go would definetly look at swapping in an 18r or 18rg motor and putiing 79 to 82 hilux/hiace disks on front.
Basically most stuff from hiaces and hiluxes up to the early 80's can be used
MR 1JZ
Re: help needed with hilux 74 Wed, 01 September 2004 09:34 Go to previous messageGo to next message
dont be a pussy, put in a 1UZFE, they go a treat and I am considering putting one in my 95 Lux, although if turbos are your thing then a 1GGTE or 1JZGTE would go a treat as well...
muli
Re: help needed with hilux 74 Wed, 01 September 2004 22:00 Go to previous messageGo to next message
with regards to 18rg, i would have to change the gearbox also, how would this affect the fact that the car is column shift, is it possible to convert to floor or no?
muli
Re: help needed with hilux 74 Fri, 03 September 2004 07:53 Go to previous messageGo to next message
does anyone know what kind of water pump i could use to replace the current one, i heard that a 18r will work?
muli
Re: help needed with hilux 74 Tue, 07 September 2004 09:33 Go to previous messageGo to next message
what mods could i do to the current engine to give it a bit of more go? bigger carby, extractors, any ideas. i really dont know a lot so i appreciate every help i can get
juzzo84
Hornsby, N.S.W
Re: help needed with hilux 74 Tue, 07 September 2004 09:42 Go to previous messageGo to next message
i cant see a 1j fitting too eaisly in the early model hilux
MR 1JZ
Re: help needed with hilux 74 Tue, 07 September 2004 10:24 Go to previous messageGo to next message
try an SR20, somone on NS has one in his either that or jack it up to the sky and slap massive tyres on it! Very Happy
muli
Re: help needed with hilux 74 Fri, 10 September 2004 03:09 Go to previous messageGo to next message
anyone know the standard power output of the 12r?
[Updated on: Fri, 10 September 2004 03:57]
CamZH
Toodyay, WA
Re: help needed with hilux 74 Sat, 11 September 2004 01:22 Go to previous messageGo to next message
I think you'll find trying to get more go out of the 12R is not really worth it...
They are an old motor...
For simplicity i'd go for an 18R-C and W50 conversion...
and to get the parts you just need to buy an old celica ! (RA23-RA40)
This will mean cutting a hole in the tunnel for the shifter, but that shouldn't be much of an issue. and you'd just remove the linkages and shifter from the steering coloumn...
You'd probably find that the 12R from stock is good for about 60-80Hp (not much!) And yours is probably tired as heck !
the 12R was never designed to make lots of power ! and you'll find it hard (impossible?) to get performance parts for it !
Cam
RA28
Re: help needed with hilux 74 Sat, 11 September 2004 01:35 Go to previous messageGo to next message
So many people pull this shit out of their celicas (18R+W50) you should be able to pick em up for a steal. I'd say pay no more than 200 bucks, unless there's work done to the 18R.
I threw out an 18R a few months ago and the W57 I had with it is collecting dust somewhere in the corner of my shed.
Tim.
muli
Re: help needed with hilux 74 Sun, 19 September 2004 05:40 Go to previous messageGo to next message
there's a 73 hilux in the trading post with a VS 3.8l 6cyl, damn i imagine this think would go alright in straight line
TA22-3SGTE
MACKAY
Re: help needed with hilux 74 Sun, 19 September 2004 12:23 Go to previous message
I replaced the old 2y in my sons hilux with a 302 Windsor , but Hilux + light truck tyres + wet roads + 302 Windsor = Hilux bent like a banana !!!!!
It was good while it lasted .
Trevor
Previous Topic:ISCV cleaning?
Next Topic:Battery re-location legality?
Current Time: Fri Nov 20 16:12:07 UTC 2026
Total time taken to generate the page: 0.0072720050811768 seconds
