Toymods » Tech & Conversions » Hilux diff splines
13BTA22
Hilux diff splines Mon, 30 August 2004 00:19 Go to next message
Hey peoples,
Just wonderind i have taken the locked centre out and put in an lsd but when i put the axles back in they will not go all the way in.No matter how hard I try and bang the axle in in.Is there and mounting pins or points that these axles normally have to line up with?
Cheers Pete
ra23celica
Re: Hilux diff splines Mon, 30 August 2004 00:34 Go to previous messageGo to next message
Sounds to me like the splines on the LSD don't match the splines on the locked diff that you just removed. Normally, with a wiggle, a grunt and a good push, the axles just slide straight in......
If I were you I would pull the diff back out and have a close look at both of these puppies side by side.
Mitch.
V8_MA61
Re: Hilux diff splines Mon, 30 August 2004 02:39 Go to previous messageGo to next message
most if not all g series hilx/ supra diffs are 30 spline.
Steve_Reynolds
Gold Coast
Re: Hilux diff splines Tue, 31 August 2004 02:50 Go to previous messageGo to next message
Pete, you can cut a few mm off the end of your axles to get them to fit. Some G series axles have different lengths. If it won't fit in by only a few mm, cut a few mm off with a cut off wheel and clean the splies up with one of those small trianular profiled files. Don't cut any more than about 4 to 5mm off. The driven splines on your axles are a few inches in length. The diving splines in the diff are only an inch or so wide, so taking a bit off the end of axles and 'sliding' them in further makes no difference to operation of the diff. It will then fit properly. If your axles protrude more than half an inch, you must have much longer axles in which case you'll need diff ones from a diff model hilux/hiace etc. Also, somtimes only one side doesn't fit, so you will only have to take a slice off one axle only. Check it out first. It will work fine.
FYI
Steve
V8_MA61
Re: Hilux diff splines Tue, 31 August 2004 03:19 Go to previous messageGo to next message
yes, hiaces have longer axles than hiluks
[Updated on: Tue, 31 August 2004 03:20]
13BTA22
Re: Hilux diff splines Wed, 01 September 2004 00:16 Go to previous message
Thanks Steve it is only just a few mm that they won't go in.I will try try th emodification of the axles.
Cheers Pete
Previous Topic:Wolf 3d engine tuners
Next Topic:locker diffs ... ??
Current Time: Sat Oct 24 14:46:10 UTC 2026
Total time taken to generate the page: 0.0048279762268066 seconds
