Toymods » Tech & Conversions » 88' Soarer Auto Trans Question?
NopartsTim
Darwin
88' Soarer Auto Trans Question? Mon, 30 August 2004 03:48 Go to next message
Gday
I have an 88 Soarer, The 2L twin turbo, 1GGTE engine with an auto transmission (Stock standard). On a side note, what is the auto tranny called?
The extension housing seal on the tranny is leaking and I have been having trouble getting the part. Can anyone tell me the part number, or alternatively who I can speak to to get the seal??
Did the same auto come in any supra's?
Thanks in advanced.
Tim
V8_MA61
Re: 88' Soarer Auto Trans Question? Mon, 30 August 2004 03:56 Go to previous messageGo to next message
yeah supras had the same. Itd be an A340E
Extension housing - you mean the bellhousing? What side of it - gearbox or motor?
These arent a 2 piece box!
If its leaking at the front itd be either your gearbox front seal, or your motor rear seal...
on a side note, the loctite brand blue gasket goo is great for sealing up boxes.
[Updated on: Mon, 30 August 2004 03:57]
NopartsTim
Darwin
Re: 88' Soarer Auto Trans Question? Mon, 30 August 2004 04:26 Go to previous messageGo to next message
Thanks for that.
I meant the rear end of the tranny, where the prop goes in. I was pretty sure it was called the extension housing. In my old ford auto (blasphemy!) they used a large rubber ring piece for the sealing.
What year supra were they released in?
Cheers!
Tim
V8_MA61
Re: 88' Soarer Auto Trans Question? Mon, 30 August 2004 04:27 Go to previous messageGo to next message
ahh the rear seal on the box?
Mine is leaking like a siv too..one day ill get around to fixing it!
NopartsTim
Darwin
Re: 88' Soarer Auto Trans Question? Wed, 01 September 2004 07:09 Go to previous messageGo to next message
I had a look at the seal, it appears to be a "non-perishable" item. Non of the parts stores I spoke to had the rear seal listed, and I couldn't get the bugger out. Its mostly metal so I suppose that makes sense.
I just ended up silastic'ing and greasing it up. Seems to have worked.
Tim
- We did our best, let silastic do the rest.
[Updated on: Wed, 01 September 2004 07:10]
V8_MA61
Re: 88' Soarer Auto Trans Question? Wed, 01 September 2004 07:43 Go to previous messageGo to next message
is it not like a sealed bearing or something?
Re: 88' Soarer Auto Trans Question? Wed, 01 September 2004 08:58 Go to previous messageGo to next message
Its a normal seal with a metal casing.
Should cost 5-10 dollars at almost any auto shop.
Its the same as almost EVERY 1988 onwards RWD Toyota
Re: 88' Soarer Auto Trans Question? Wed, 01 September 2004 10:05 Go to previous message
requires a puller to remove.
Previous Topic:Internal or external?
Next Topic:TA22 High Beam...
Current Time: Tue Oct 27 11:38:53 UTC 2026
Total time taken to generate the page: 0.0063269138336182 seconds
