Classifieds » Miscellaneous » MoTec for sale!!!! Price drop
ke553sgte
sa
icon2.gif  MoTec for sale!!!! Price drop Mon, 30 August 2004 03:52 Go to next message
G'day guys, I am selling the Motec I am running on my circuit car. The system is the 3D version 4.2, it comes with all the gear needed to get it running.
Witch includes hand controller, loom, coil packs(and a band new set of coil packs that have never been used), crank angle sensor, relays and so on.
It was on a 3sgte and is tuned to suit, on the dyno it made 220kw at the wheels with the 36mm restrictor in place. It can be tuned to suit any engine and completely tuned through the hand set. It is one of the older Motec systems but is still very good condition. The system is still on the car so if anyone wants to hear it running that can be arranged. Im located in SA and the system need to go to fund a new set up on the car.
Price is now $1200 and will consider any reasonable offer.
[Updated on: Wed, 01 September 2004 22:56]
Sharpie
Re: MoTec for sale!!!! Mon, 30 August 2004 04:25 Go to previous messageGo to next message
Sounds sweet. What injectors are you running to get 220rwkw?
datto_boy
Re: MoTec for sale!!!! Mon, 30 August 2004 06:26 Go to previous messageGo to next message
are you sure it can be tuned to suit everything? some computers you cant anymore.
if you still have it in a couple if weeks i will be keen.
ke553sgte
sa
Re: MoTec for sale!!!! Mon, 30 August 2004 06:46 Go to previous messageGo to next message
Injectors used at the moment are 12a turbo with custom fuel rail. I should say that you can tune this car to any 4 cylinder engine as it only has 4 injector drivers. This is a very simple engine managment system to work with one look at the insruction manual and you would no what I mean.
crazyracer
Re: MoTec for sale!!!! Mon, 30 August 2004 09:29 Go to previous messageGo to next message
I used to have one of these and they are a pretty good ECU which can be programmed to suit pretty much anything.
They are probably similar to the original Wolf 3D ECU, but with more flexibility in the mapping. They can be programmed by Laptop but require an adaptor unit which is hard to find these days, but most of the motec agent will have one if you get them to tune your car. Otherwise you can just use the hand controller.
They are batch fire only (non-sequential) but can handle DFI with the addition of a dumb DFI ignition expander.
The other limitation is that they accept a reasonably limited selection of sensors so you may not be able to use some of the sensors that are on you engine, and may need to change to older style ones that were available when this ECU came out but these can quite often be sourced down the wreckers these days as they are common 80's Bosch items.
Sharpie
Re: MoTec for sale!!!! Mon, 30 August 2004 23:42 Go to previous messageGo to next message
ke553sgte wrote on Mon, 30 August 2004 16:46
Sounds good, I kinow some one who might be interested. I'll let you know.
3sglevin
Re: MoTec for sale!!!! Tue, 31 August 2004 00:06 Go to previous messageGo to next message
This is too cheap! I cant believe you still have it. These are well over $2,000.00 new. Good luck with the sale free bump!
p.s. this is from Pete Tillets old car isnt it?
ke553sgte
sa
Re: MoTec for sale!!!! Tue, 31 August 2004 00:52 Go to previous messageGo to next message
Yeah this was of peter's old car (originally chris bailey)good managment system but need something with just a few extra aux outputs to suit the new engine set up in the car.
horner boy
Re: MoTec for sale!!!! Tue, 31 August 2004 10:45 Go to previous messageGo to next message
free bump
Sharpie
Re: MoTec for sale!!!! Price drop Wed, 01 September 2004 23:16 Go to previous messageGo to next message
Sorry mate but the guy who was keen has changed his mind.
Razz
Free bump anyway.
Galactic Soap
Sydney, The Hills District
Re: MoTec for sale!!!! Price drop Wed, 01 September 2004 23:20 Go to previous messageGo to next message
How would this go with the following engine
setup:
4AGZE Bottom End, T28, regular GZE Injectors
At the moment I'm tossing up between this and
a Microtech LT8, please exucuse my ingnorance lads
but would you guys suggest ?
Soapy
spectral
Re: MoTec for sale!!!! Price drop Thu, 02 September 2004 01:16 Go to previous messageGo to next message
have you got a webpage with the specs on it? I can only find specs for the M4 etc..
* number of fuel/ignition maps ? points per map?
* inputs : TPS/MAP/CAS etc, corrections (Temp etc?) ?
* can it control boost?
* closed loop?
hks89supra
Re: MoTec for sale!!!! Price drop Thu, 02 September 2004 02:15 Go to previous messageGo to next message
is this still for sale???? Very keen!!!!!
Im guessing only four (4) coil packs are included, if so how/where to get additional ones
ke553sgte
sa
Re: MoTec for sale!!!! Price drop Thu, 02 September 2004 03:06 Go to previous messageGo to next message
The main funcions of this ECU are as follows-
-fuel trim every 500 RPM
-ignition trim every 500 RPM
-6 light load setting
-6 heavy load settings
-Boost limit
-Cold start
-RPM limit
-Boost limit
It also has one Aux output taht can control-
-Wategate
-Idle speed
-Fans
-Air conditioner
-Waste gate control+Fuel pump control for anti stall
-Tacho out put
-RPM activated switching
-Nitrous oxide
The system does have Lambda control but I was running open loop on my car. I was using the aux output for fans so I dont have the boost control solenoid for the system but it is still avalible through motec. I have never used half of the functions on this ECU as it was in a race car. As said it is one of the first of the motec systems but is very good, the only reason I am selling it is with the new engine setup in the car I need a few more Aux outputs. The unit comes with a second set of four coils that have never been used. It also comes with the air intake temp sensor and map sensor an dhand controller. It can be tuned better through a laptop which all motec dealers shold have the softwear for.
hks89supra
Re: MoTec for sale!!!! Price drop Thu, 02 September 2004 04:00 Go to previous messageGo to next message
PM'ed you
ae86drift
sydney.au
Re: MoTec for sale!!!! Price drop Sun, 19 September 2004 06:58 Go to previous messageGo to next message
16 or 32 bit maps?
very interested.
spud86
melbourne
Re: MoTec for sale!!!! Price drop Wed, 29 September 2004 10:54 Go to previous messageGo to next message
What model motec is it, how much are you asking for it and where is the ecu
stumpy
perth WA
Re: MoTec for sale!!!! Price drop Wed, 29 September 2004 18:48 Go to previous messageGo to next message
If its not to much trouble, what are the dimensions of the casing?
bazooked
Re: MoTec for sale!!!! Price drop Thu, 30 September 2004 09:30 Go to previous messageGo to next message
hey dude is the motec still available? as i am very intrested and have the cash if we come to an agreement.
graeme.
STR8 2.8
Re: MoTec for sale!!!! Thu, 30 September 2004 09:42 Go to previous messageGo to next message
couldnt you just batch fire them,
thereby making 6 or more cylinder engines runable
bazooked
Re: MoTec for sale!!!! Fri, 01 October 2004 09:41 Go to previous messageGo to next message
anybody home??
Re: MoTec for sale!!!! Fri, 01 October 2004 16:00 Go to previous messageGo to next message
PM him
dunno why this hasn't sold yet?
Sharpie
Re: MoTec for sale!!!! Fri, 01 October 2004 21:58 Go to previous messageGo to next message
It has sold.
bazooked
Re: MoTec for sale!!!! Fri, 01 October 2004 23:54 Go to previous messageGo to next message
got no idea dude i sent him a pm and a email??
bazooked
ohwell
Previous Topic:500hp fuel pump, surge tank, etc, make an offer.
Next Topic:Dragway Mags and Hilux Locked Centre Pics Available
Current Time: Sun Nov 22 01:30:19 UTC 2026
Total time taken to generate the page: 0.037090063095093 seconds
