Toymods » Tech & Conversions » Koni adjustable shocks - how to adjust? -Sprinter
papercut
Koni adjustable shocks - how to adjust? -Sprinter Mon, 30 August 2004 04:01 Go to next message
Hi guys,
I was told by the pervious owner of my car that it has Koni adjustable yellow shocks. I was just wondering how these shocks are 'adjusted' and how do i know once i adjust each one that they will be all the same shock rate?
The have no dials or anything, so how?
cheers!
[Updated on: Tue, 31 August 2004 00:13]
wilbo666
Re: Koni adjustable shocks - how to adjust? Mon, 30 August 2004 04:35 Go to previous messageGo to next message
I thought that koni yellows were externally adjustable via a knob on the top of them? Some konis are adjustable once they are off the car also though, but I'm pretty sure yellows are an on car type... (you have to press them all the way down and then turn).
You could try winding them both to full softness and then adjust both shocks the same amount till your happy (x.x turns, make a note of where they were to start with so you can always go back!). If one is more worn than the other this will prbly not work very well tho!
[Updated on: Mon, 30 August 2004 04:36]
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: Koni adjustable shocks - how to adjust? Mon, 30 August 2004 04:36 Go to previous messageGo to next message
Isn't there a little white knob/handle thing that u use to adjust the damper rate? Surely you can buy a new one if need be.
Toobs
Re: Koni adjustable shocks - how to adjust? Mon, 30 August 2004 04:39 Go to previous messageGo to next message
Depends on whether you have externally adjustable shocks or internally adjustable ones.
The externally adjustable ones have an attachable knob that you use to adjust the dampening.
Go to the Koni website if you want to know any more.
http://www.koni.com/
improvedae86
Re: Koni adjustable shocks - how to adjust? Mon, 30 August 2004 04:41 Go to previous messageGo to next message
If there are yellows they should be adjustable on the shock shaft at the top in the car by a small tab {in the center of the shaft}, which you use a plastic Koni nut to adjust {or small spanner}. They could be reds with yellow valving , which means your compress the shock till the shaft clicks into the body then turn the shaft . Or depending on part numbers they could be the Yellow race shocks which have one adjustment dampening / compression adjustment by the top dial , and rebound by the rotation of the shaft . These where not sold in Australia , but they might be those if the shocks where imported . + adjustment is clockwise - anticlockwise .
papercut
Re: Koni adjustable shocks - how to adjust? Mon, 30 August 2004 05:03 Go to previous messageGo to next message
thanks guys.
well im assuming they are the 'Yellow' model because they are yellow in colour (is this correct? - or is there a difference between a yellow koni shock and an actual 'Yellow' model?)
i can see the shaft at the top of the shock inside the car, it looks as though some sort of nut key can adjust them. So all i do is wind them back and forth to get damper pressures? I'm thinking if a normal spanner can achieve this.
also - the front of my car has coil overs. Can i access the top of the shocks on the top of the struts? (under the rubber plug)?
paddles
Re: Koni adjustable shocks - how to adjust? Mon, 30 August 2004 06:00 Go to previous messageGo to next message
I had yellow ones that were internally adjustable on my rally car, if that's what you've got then then disconnect the top of the shock from the car and remove the bump stop from inside the dust cover by pushing it down the shaft using a bit of wire or a screwdriver. Then fully compress the shock by hand, which meshes an internal valving adjuster and turn the dust cover (with shock still compressed) to change the damping. Don't forget to put the bump stop back in when you're done because if the shock "bottoms out" without it you'll wreck the internal adjuster.
Stefan
Hobart, Tas
Re: Koni adjustable shocks - how to adjust? Mon, 30 August 2004 06:20 Go to previous messageGo to next message
Unfortunatley, not all yelows are internally adjustable. Yellows for xA6x celicas and supras, for example, are internally adjustable only.
What car are these on?
papercut
Re: Koni adjustable shocks - how to adjust? Mon, 30 August 2004 07:05 Go to previous messageGo to next message
they are on my 84 sprinter
anyone can help me with the front ones>?
Ribbo
Northern Beaches
Re: Koni adjustable shocks - how to adjust? Mon, 30 August 2004 22:32 Go to previous messageGo to next message
I have yellows on the front of my sprinter. There is a small bit on top kinda like the head of a flat head skrew driver, you need to use a tool that you put over it and push down and you can turn them.
PerformanceCars
Re: Koni adjustable shocks - how to adjust? Mon, 30 August 2004 23:35 Go to previous messageGo to next message
as others have said, the koni yellows for a sprinter are only internally adjustable.
there is 2 1/4 turns of adjustment. screwed all the way in is hard & all the way out is soft.
Interesting fact is that the "adjustability" of the shocks was originally intended to compensate for age and wear - ie as they got older you adjusted them harder to compensate.
anybody have any koni yellow rears they want to sell? im on the prowl for a set...
papercut
Re: Koni adjustable shocks - how to adjust? Tue, 31 August 2004 00:11 Go to previous messageGo to next message
Ribbo wrote on Tue, 31 August 2004 08:32
PerformanceCars wrote on Tue, 31 August 2004 09:35
hmmmm......these two comments seem to contradict?
So what your saying is SOME yellows are only EXTERNALLY adjustable?
PerformanceCars
Re: Koni adjustable shocks - how to adjust? -Sprinter Tue, 31 August 2004 00:25 Go to previous messageGo to next message
Do you have 86 struts in ribbo? the koni yellows for 86's arent externally adjustable.
says so on their catalogue too.. the externally adjustable ones have a http://www.koni.com/_cars/symbole/images2/symbol2_v.gif
Stefan
Hobart, Tas
Re: Koni adjustable shocks - how to adjust? Tue, 31 August 2004 00:30 Go to previous messageGo to next message
Are they AE92 ones by any chance? Shorter stroke than stock?
papercut
Re: Koni adjustable shocks - how to adjust? -Sprinter Tue, 31 August 2004 00:53 Go to previous messageGo to next message
hmm ok.
so chances are that my shocks are ALL internally adjustable only?
The car feels sloppy and i think i'm due for a re-gas/adjustment.
Whats involved in this? do they take my whole coil-over setup off and remove the shock? The back ones would be fairly easy i imagine.
How much?
bbaacchhyy
Re: Koni adjustable shocks - how to adjust? Tue, 31 August 2004 01:05 Go to previous messageGo to next message
papercut wrote on Tue, 31 August 2004 10:11
Yep. My fronts (from a RAV4) are externally adjustable, whereas the rears (from a MA70) are internally adjustable.
The colour of the shocks is part of the way that they identify the purpose of their range. Red is general, Yellow is Sport etc...
[Updated on: Tue, 31 August 2004 01:07]
RobertoX
Re: Koni adjustable shocks - how to adjust? -Sprinter Tue, 31 August 2004 01:21 Go to previous messageGo to next message
Getting shocks rebuilt involves removing from car, yes Smile
I'm sending my rear reds off to be done this week, They are getting yellow valves though... Cost about 150 and they come back as good as new...
PerformanceCars
Re: Koni adjustable shocks - how to adjust? -Sprinter Tue, 31 August 2004 01:22 Go to previous messageGo to next message
papercut wrote on Tue, 31 August 2004 10:53
hmm ok.
How much?
Koni's are pretty good and last a long time - I'd try adjusting them first. If they are still sloppy after that take them to somewhere like fulcrum who has a (off car) shock dyno. They can dyno the shock and get the proper measurements from koni and tell if they are worn. If so they can be rebuilt. the 86 shocks dont use gas - they are oil filled only.
papercut
Re: Koni adjustable shocks - how to adjust? -Sprinter Tue, 31 August 2004 01:31 Go to previous messageGo to next message
alright sounds about right.
Does anyone recommend Pedders? there is one near me, just thinking how long i will be without a car for!
paddles
Re: Koni adjustable shocks - how to adjust? -Sprinter Tue, 31 August 2004 03:11 Go to previous message
Try and find someone who can actually rebuild the shocks inhouse, that'll save you a bit of money in handling/transport. Generally if you want a really good job done for car setup avoid the bigger chains and go to a smaller more specialised suspension shop. I can recommend a couple in brissy but you're probably not from here Smile
Previous Topic:ta22 (23) + 1ggte
Next Topic:What steel for flywheel?
Current Time: Thu Oct 22 03:59:10 UTC 2026
Total time taken to generate the page: 0.0056319236755371 seconds
