Toymods » Tech & Conversions » TA22 High Beam...
Disco Scoob
TA22 High Beam... Mon, 30 August 2004 09:26 Go to next message
Hey guys, my celica is up for rego, but i don't think it will pass because the high beam doesn't work.
Basically when you switch it on, all the lights go off.
Has anyone got any ideas on how to fix it?
i have pulled the mechanism of the steering column and it seems fine, ie all the switches make contact. Could it be a relay or wiring? (wires seem fine)
Any help would be great.
Thanks, Sean.
Laughing P.S its not the globes, i tried that. Thanks. Smile
BradW
Bottom of the hill, Sydney
Re: TA22 High Beam... Mon, 30 August 2004 09:57 Go to previous messageGo to next message
Search the tech & conversion section for a thread titled
Ta22 and flasher unit/sss
In this thread there is a post by Azrael which has a link to a wiring diagram for a TA22. Have a look at the colour coded diagram. It is easier to follow. I would suggest checking your dipper switch wiring with a test light. It switches the negative to change beams.
With the headlights on and the dipper switch unplugged try earthing the red/yellow wire then the red/green wire. This should trigger the high and low beams. If the lights work check for an earth at the dipper switch (should be white/black).
If all the wiring checks out try a new dipper switch.
Good luck and let us know how you go.
Brad
Disco Scoob
Re: TA22 High Beam... Wed, 01 September 2004 08:43 Go to previous message
Thanks Brad, ill give it a try tomorrow afternoon.
Thanks again, Sean.
Previous Topic:88' Soarer Auto Trans Question?
Next Topic:2tg elec dizzy fit 18r-g???
Current Time: Thu Oct 29 08:03:28 UTC 2026
Total time taken to generate the page: 0.029098987579346 seconds
