Toymods » Tech & Conversions » help with 3T GTE ehaust manifold gasket
tbowgn
Adelaide SA
icon5.gif  help with 3T GTE ehaust manifold gasket Mon, 30 August 2004 09:29 Go to next message
hi guys i need urgent help with an exhaust manifold gasket. Its for a 3t gte i rang the toyota places in adelaideand the only way i can get 1 is order from japan. What im wondering is if there are any others that will fit,like the 3TC gasket.
any help will be appreciated thanks kyle
suprra_girl
Auckland, NZ
Re: help with 3T GTE ehaust manifold gasket Mon, 30 August 2004 09:47 Go to previous messageGo to next message
why don't you just get one made, probly cost ya 30 bucks or something and you'd probly pay that for one from toyota
my 2c Wink
Suze
Re: help with 3T GTE ehaust manifold gasket Mon, 30 August 2004 09:51 Go to previous messageGo to next message
2t, 3t, 2tg and 3tgte are all same from memory.
gas miser sell them, available from autobarn
CLG
Perth, Western Australia
Re: help with 3T GTE ehaust manifold gasket Mon, 30 August 2004 09:52 Go to previous messageGo to next message
Yep any 2T/3T gasket will fit, thought the original 3TGTE items are the graphite type, so take the heat a bit better. Given however the last time I priced one up (around $160 from memory?), and the 5 week wait, I simply used an aftermarket pressed item with High temp silicon, to good effect.
kingmick
Banned by his request
moved to tamworth
Re: help with 3T GTE ehaust manifold gasket Mon, 30 August 2004 10:38 Go to previous messageGo to next message
if you get really stuck. the best way and better than an factory one is to make one out of copper. not that much work, just get a good grade of copper sheet in 1mm and trace around with the old gasket or use the exhaust manifold. then before you cut it out place the sheet on a soft bit of wood{pine,oregon etc) the same size. then get a big crap srew driver and round the end of so it cant cut threw the copper and gently make a ridge about half way between the inside marking for the exhaust port and the out side of the marked gasket. the ridge just needs to be above the main sheet not huge. then cut the out gasket with a band saw,jigsaw or tin snips. then do the inner holes by drilling a large hole inside the market exhaust ports and the cut it out with a jig saw or drill with a smaller drill all the way around inside the port mark and file it straight and neat. then line it up on the exh manifold and mark the bolt holes and then center punch them and drill them. dont make the holes to much bigger than the bolts so you can keep the gasket centred and once you have done them all put all the bolts into the exh manifold and put the gasket over them and check you dont block the ports.
mick
fade-e
Re: help with 3T GTE ehaust manifold gasket Mon, 30 August 2004 11:19 Go to previous messageGo to next message
CLG wrote on Mon, 30 August 2004 19:52
is there any difference in using a normal exhaust gasket compared to extractor gasket? would the extractor gasket be better since it is much thicker
YelloRolla
On your mum!
Re: help with 3T GTE ehaust manifold gasket Mon, 30 August 2004 12:33 Go to previous message
ACL part number is JA053 - run into repco/autopro etc and quote that number.
Previous Topic:ST185 GT4 Group A Bumper
Next Topic:Rt130 Brake conversion and camber/TA22
Current Time: Sat Oct 24 03:58:06 UTC 2026
Total time taken to generate the page: 0.0039970874786377 seconds
