Toymods » Tech & Conversions » Rt130 Brake conversion and camber/TA22
ta2272
icon3.gif  Rt130 Brake conversion and camber/TA22 Mon, 30 August 2004 10:19 Go to next message
going to put this strut into my car and drop the spring perch down so the ride hight is the same as before with the same spring, how would this effect my camber?
also if this is done would this make the spring loose when the suspension is full extended.?
and would i have to get it engeeneered/QLD.?
SeptemberSquallIndustries
Re: Rt130 Brake conversion and camber/TA22 Mon, 30 August 2004 11:38 Go to previous messageGo to next message
This is totally not the way to go about it. You're simultaneously;
1. reducing bump stop clearance
(leading to bottoming out after minimal/insufficient travel),
and
2. losing spring captivity at full extension
(how did you think that increasing the distance between the spring seats at full extension wasn't going to affect spring captivity..?)
I'm doing this at the minute and there's a lot to consider. PM me if you like for details?
Last I heard it was perfectly legal to modify suspension components by welding without any inspection at all. Have fun!
ta2272
Re: Rt130 Brake conversion and camber/TA22 Mon, 30 August 2004 11:43 Go to previous messageGo to next message
thats why im asking the question, Razz
With stiffer springs and shocks is the 2cm's les travel going to make much difference anyway.
Anyone else who can give the answer or another way to do it, i have been told you can easily modify mr2 or corrolla shocks to fit which have a shorter stroke.
Thanks Jason
Re: Rt130 Brake conversion and camber/TA22 Mon, 30 August 2004 12:23 Go to previous message
Like you said, 2cm is stuff all in effect. 2cm may be fine, but you'll want more.
There are a few options, PM me for some recepies?
Previous Topic:help with 3T GTE ehaust manifold gasket
Next Topic:how mcuh kw? 4agze
Current Time: Sat Oct 24 06:03:39 UTC 2026
Total time taken to generate the page: 0.004688024520874 seconds
