Toymods » Tech & Conversions » valves for 3TGTE
fade-e
valves for 3TGTE Mon, 30 August 2004 12:23 Go to next message
are the 2TG and 3TGTE in/ex valves the same size?
YelloRolla
On your mum!
Re: valves for 3TGTE Mon, 30 August 2004 12:24 Go to previous messageGo to next message
In my experience - yes. But I have not disassembled all types of 2T heads.
fade-e
Re: valves for 3TGTE Mon, 30 August 2004 12:51 Go to previous messageGo to next message
cool its just iw as going through the wilkins site and they only have the 2TG valves in/ex... also it says that the 2TG and 3TG bearings are the same too, is that right?
also finally are all the timing chains, tensioners and stuff the same between the 2?
Jonny2TG
Tasmania
Re: valves for 3TGTE Mon, 30 August 2004 12:56 Go to previous messageGo to next message
Most stuff is the same between 2T-G and 3T-GTE. Bearings should also be common to 3T-C. Rings can be different, different thickness.
Early 2T-G (-88220) have smaller valves. All others and 3T-GTE should be the same.
Timing chains are the same.
fade-e
Re: valves for 3TGTE Mon, 30 August 2004 12:58 Go to previous messageGo to next message
ok sweet, just starting to prepare everything for a motor rebuild and just want to make sure i dont buy the wrong stuff... i should ask them when i get there hopefully they will know Rolling Eyes and not be 'what s the part number you want?' types
YelloRolla
On your mum!
Re: valves for 3TGTE Mon, 30 August 2004 13:13 Go to previous messageGo to next message
The chain dampener at the front of the head in between the cam gears is different for the 3T GTE compared to the 2TG. The 3T one is relieved for the oil breather.
Chains are the same.
Be careful when assembling with aftermarket con-rod big end bearings - the oil squirt holes for the thrust side of the pistons do not line up with some brandes and the bearings need to be drilled accordingly.
Rings should come with the pistons that you buy.
Jonny2TG
Tasmania
Re: valves for 3TGTE Mon, 30 August 2004 13:26 Go to previous messageGo to next message
Chain dampeners are not avaliable anyplace anymore as far as I know.
Note: Guys are Repco will have no idear what a 3T-GTE engine is. Do the homework yourself. The ACL book they use will list the 2T-G and 3T-GTE engines as being 16 valve. This is a obvious mistake so don't let it trip you up. Grap the book off the parts guy and change it with a pen yourself.
fade-e
Re: valves for 3TGTE Mon, 30 August 2004 13:40 Go to previous message
Laughing can i grab the parts and run off with them too? Rolling Eyes he is only an employee what does he care Laughing
yeah but like i said i might have a chat to the wilkins people see what they say, otherwise i can always rely on Jason and Rod Rolling Eyes Very Happy
Previous Topic:corona v8 conversion
Next Topic:AE82 and AE92 manual conversion
Current Time: Fri Oct 23 16:49:57 UTC 2026
Total time taken to generate the page: 0.006619930267334 seconds
