Toymods » Tech & Conversions » 5me - 5mge alternator
Supralux
5me - 5mge alternator Mon, 30 August 2004 13:27 Go to next message
I have a 5me alternator with two large thick white wires, one black/yellow wire, one black/red wire and one other colour wire which have been cut off. problem is that it is on a 5mge engine.
This 5mge engine has two large thick black/red wires, one black/yellow wire, one black/red wire and one other colour wire sticking out which have been cut off. I have looked at several wiring diagrams and am still unsure of correct wiring. can someone lead me in the right direction here?
82MKII
Re: 5me - 5mge alternator Mon, 30 August 2004 14:19 Go to previous messageGo to next message
You should only have 4 connections to the alternator (5me or 5mge).
1. The +B terminal that delivers current from the alternator. This should have a thick white wire coming from it. This is a separate terminal with a nut on it to do up the white wire.
The other three connections below are all through a 3 pin plug.
2. The IG terminal. This is the feed from the ignition switch (via the IG relay) to the alternator. This should be Black/Yellow.
3. The S terminal. This is what the alternator uses to measure the battery voltage and determine what voltage it should output. This is normally black.
4. The L terminal. This is what drives the charge lamp. With the ignition on, and the plug disconected from the alternator if you ground this terminal, the charge lamp should come on.
With a mutimeter you can identify IG. Then sort out which one L is, the one left is then S.
Regards
Peter
Supralux
Re: 5me - 5mge alternator Tue, 31 August 2004 01:56 Go to previous messageGo to next message
ok thanks. but where do the red/black thicker wires go to then? the engine wiring diags dont show the alternator stuff.
82MKII
Re: 5me - 5mge alternator Tue, 31 August 2004 12:55 Go to previous messageGo to next message
I'm guessing - but maybe someone has rewired it and the red/black thicker wires are meant to take the place of the thick white wires. Do they have a lug on the end of them?
Regards
Peter
Supralux
Re: 5me - 5mge alternator Tue, 31 August 2004 14:48 Go to previous messageGo to next message
no they dont have lugs on the end, im guessing they have been cut off. they are the only wires on the engine which do not go anywhere.
also they are on the wrong side of the engine to link to the alternator. confusing stuff
Re: 5me - 5mge alternator Wed, 01 September 2004 00:23 Go to previous messageGo to next message
Supralux wrote on Tue, 31 August 2004 22:48
Then they are are ignition wires (wires that come 12v when IGN is ON).
I can't remember where they went on my 6mge, as its been a while.
As long as the alternator wire that gets bolted on is on there, and the other end is connected to the battery, the rest doesn't matter.
Its only indication lights.
EDIT: Unless it has some sort of safety mechanism with the other wires.
[Updated on: Wed, 01 September 2004 00:25]
Supralux
Re: 5me - 5mge alternator Wed, 01 September 2004 01:29 Go to previous message
alright. I will be trying to get all of my gauges working sooner or later tho. im a bit of an electronic noob. no idea really.
Previous Topic:Changing brake pads [S4 mazda FC3s calipers]
Next Topic:Black Smoke
Current Time: Sun Oct 25 16:00:17 UTC 2026
Total time taken to generate the page: 0.0053701400756836 seconds
