Toymods » Tech & Conversions » What steel for flywheel?
Jayem
Finland
What steel for flywheel? Mon, 30 August 2004 14:39 Go to next message
Must be cheapish and easily available.
I was thinking Fe80.
Jayem
Finland
Re: What steel for flywheel? Mon, 30 August 2004 14:48 Go to previous messageGo to next message
...and I would like to avoid heat treatment.
510rob
Vancouver
Re: What steel for flywheel? Mon, 30 August 2004 19:34 Go to previous messageGo to next message
Use a piece of 4140-HTSR chrome-moly low alloy (HTSR = heat-treated, stress-relieved), ring gears are usually 1040-1050 medium carbon steel. Press the ring gear on, then TIG weld a few stripes to make sure it stays put...
Jayem
Finland
Re: What steel for flywheel? Mon, 30 August 2004 22:10 Go to previous messageGo to next message
Thanks! 4140 sounds like American standard number for that steel. If so do you know international standard number?
About ring gear, I was going to use the original one. Just install it the way you described.
Skip
Re: What steel for flywheel? Mon, 30 August 2004 23:39 Go to previous messageGo to next message
You wont need to know any other number cause anyone you buy a billet from will know what 4140 or 4130 etc is.
ed_ma61
Lost in the K hole
Re: What steel for flywheel? Tue, 31 August 2004 00:13 Go to previous messageGo to next message
4130 is good stuff
510rob
Vancouver
Re: What steel for flywheel? Tue, 31 August 2004 02:46 Go to previous message
I will say again, whatever material you get (4140!!!), make sure you specify that it must be HEAT TREATED STRESS RELIEVED material.
Previous Topic:Koni adjustable shocks - how to adjust? -Sprinter
Next Topic:RA23/28 engine bay measurements for body repairs now w/pic
Current Time: Fri Oct 23 02:58:47 UTC 2026
Total time taken to generate the page: 0.0053319931030273 seconds
