| Author | Topic |
can you explain my diff Phenomena
Tue, 31 August 2004 00:45
ok i think my diff has just about had it, its turned into a locker
when i jacked it up both wheels turn the same way, however when i drive it it doesnt lock unless i load it up, anyone explain whats going on in the centre??
tar
Re: can you explain my diff Phenomena
Tue, 31 August 2004 03:41
My guess is that the satellite bearings are stuffed.
Tue, 31 August 2004 08:00
when its in the air are u spinning them using the engine or by hand, cause if its in gear getting turned by the engine, thats just how it works
Tue, 31 August 2004 08:10
worn spider gears
worn single spinner diffs act like lsds
Tue, 31 August 2004 08:21
turning by hand
Thu, 02 September 2004 11:49
Better- how to accalerate wear to that point & keep it there for around 200,000kms?
Thu, 02 September 2004 12:07
take the centre out and weld the sun gears up
Thu, 02 September 2004 20:06
| feral wrote on Fri, 03 September 2004 00:07 | take the centre out and weld the sun gears up
No, because then it wouldn't act like an LSD
Besides, I've done that with my other diff... damn I've gone from having one locked diff to one open, one locked and one spare diff head... all 4 pinion G series
