Toymods » Tech & Conversions » sprinter ball joint
cri_ag
northern beaches
sprinter ball joint Tue, 31 August 2004 12:16 Go to next message
the sprinter had an interlude with a gutter on the weekend and im now in the process of replacing bent bits. i have replaced all the damaged bits, but CLG sugested to me that i may need to replace my steering ball joint. is this a part i can buy new from repco or the like as a friend sugested? or do i have to use a second hand item?
SeptemberSquallIndustries
Re: sprinter ball joint Tue, 31 August 2004 14:34 Go to previous messageGo to next message
You didn't call Repco before you asked this did you?
CLG
Perth, Western Australia
Re: sprinter ball joint Tue, 31 August 2004 15:40 Go to previous messageGo to next message
I actually suggest you also replace your steering knuckle after reading the list of parts you'd bent, but the ball joints (lower control arm, and steering tie rod ends) should als be addressed too.
Re: sprinter ball joint Wed, 01 September 2004 13:15 Go to previous message
Yes, they're easy+cheap to buy, and easy to replace. However, if you haven't done this before you'll probably think it's an absolute bugger of a job Cool It's not so much about applying force, more about applying it in the right place!
Previous Topic:AW11 S/C Immobiliser wiring help
Next Topic:Internal or external?
Current Time: Thu Oct 29 06:55:23 UTC 2026
Total time taken to generate the page: 0.0043041706085205 seconds
