Toymods » Tech & Conversions » Injector sizes in some Toyota motors
Youngy
Eskilstuna, Sweden
Injector sizes in some Toyota motors Wed, 01 September 2004 00:42 Go to next message
Hello all,
I am just after some clarification on the standard injector sizes and interchangeability between engines for the injectors.
For example is this correct?
3SGE\3SGTE - 370cc injectors
7MGTE - 440cc injectors (not sure if the 7MGE are the same size)
4AGE 20V - 290cc injectors
4AGZE - 370cc injectors
Now can you get say 7MGE injectors and put them in a 3SGE and or vice versa (why would you, I know)?
Joshstix
Toymods Vice President
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 02:32 Go to previous messageGo to next message
The 3S-GTE stuff is wrong as far as I know.
Gen2 3S-GTE 440cc
Gen3 3S-GTE 550cc
ed_ma61
Lost in the K hole
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 02:50 Go to previous messageGo to next message
7mge injectors are 295cc/min or 315cc/min depending on which pressure you test them at - different spec sheet use different test pressures so it can get a little confusing.
joorsh
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 02:52 Go to previous messageGo to next message
What about 7MGTE injectors?
-J-
ke382TG
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 03:00 Go to previous messageGo to next message
I use these on my 4AGTE, depending on who you ask they either say 430cc or 440cc. Pretty sure when I bought mine each box said 430cc on them (but I can't really remember).
ed_ma61
Lost in the K hole
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 03:01 Go to previous messageGo to next message
joorsh wrote on Wed, 01 September 2004 12:52
-J-
440cc/min
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 03:32 Go to previous messageGo to next message
ed_ma61 wrote on Wed, 01 September 2004 10:50
Ed, I thought the lo impedance ones were 295, and the hi impedance ones were 315?
Youngy
Eskilstuna, Sweden
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 05:11 Go to previous messageGo to next message
Joshstix wrote on Wed, 01 September 2004 12:32
Gen2 3S-GTE 440cc
Gen3 3S-GTE 550cc
So are the 3SGE ones 370cc then?
7mgte83
Barossa valley SA
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 07:08 Go to previous messageGo to next message
A guy who bought 7mgte injectors from me said he had them flow tested at about 260-280?
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 07:10 Go to previous messageGo to next message
7mgte83 wrote on Wed, 01 September 2004 15:08
Then they were blocked
7mge ones flow more than that.
Unless he was testing it at the wrong pressure, or with the wrong voltage.
ChuckLandwehr
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 08:32 Go to previous messageGo to next message
You can find most Toyota injectors, sizing and engine application at this site:
http:www.toysport.com/webpages/Techinfo/References /injectors.htm
regards Chuck.
ed_ma61
Lost in the K hole
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 10:12 Go to previous messageGo to next message
CrUZsida wrote on Wed, 01 September 2004 17:10
nah... flow testing injectors is like comparing diferent cars on a chasis dyno - the figures you get shouldnt be used to compare the injectors to what they are spec'd in some catalogue, nor to compare to other injectors flow tested on another machine at another workshop. flow testing is for tuning and balancing that set of injectors, on that machine, on that day only.
its totally futile to say the 7mgte injectors are 440cc/min, but *really* only flow 280cc/min. just wrong.
more correctly, using whatever standardised technique established by the manufacturer (eg bosch, ND etc), they are 440cc/min units, and flow twice as much as standardised 220cc/min units.
take either injector to joe schmo injector man, and he'll always get different flow numbers, cause he'll use a different test method. but the 440's will still flow twice as much as the 220's.
as long as the injector is 'big enough' it really doesnt matter any more...
oh, and the 7mge injectors, yes one is low and the other high imp, however, look at the test pressure in the cat for each of these inj types: the 315cc inj is rated at 41psi (i think) versus 38psi (i think) for the 295cc units. basically they flow exactly the same, but they do have different imp values.
FLY PSI
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 10:44 Go to previous messageGo to next message
Gen2 3S-GTE 440cc
Gen3 3S-GTE 550cc
what impedence (high or low) are both the injectors? and are they both side feed?
Youngy
Eskilstuna, Sweden
Re: Injector sizes in some Toyota motors Wed, 01 September 2004 12:06 Go to previous messageGo to next message
Thanks Chuck, nice info on that site.
Joshstix
Re: Injector sizes in some Toyota motors Thu, 02 September 2004 01:33 Go to previous messageGo to next message
I have no idea about the 3SGE injectors, however I'd be surprised if they didn't change between generations of the engine as there is a huge change in the amount of power they have to support.
As to the 3S-GTE ones I don't know the impedence, however I do know that the 550's are a direct replacement for the 440's and are the same as the US 2JZ-GTE injectors.
Bugman
Re: Injector sizes in some Toyota motors Thu, 02 September 2004 03:38 Go to previous messageGo to next message
also with 3s-gte it differed if it came from a group a gt4 or a normal gt4 didnt it?? or a mr2 .. the group a's got a slightly bigger injector and the higher factory boost cut of 18psi
ChuckLandwehr
Re: Injector sizes in some Toyota motors Thu, 02 September 2004 11:32 Go to previous message
Dial up "toysport.com" on the net. Most Toyota injectors, resistance, flow and their engine applications can be found at this site.
regards Chuck.
Previous Topic:Brake limitations....
Next Topic:GZE Probs
Current Time: Sun Oct 25 17:16:29 UTC 2026
Total time taken to generate the page: 0.11241602897644 seconds
