Toymods » Tech & Conversions » 1G-GTE only running for ~5 minutes
HyDrA
Adelaide, SA
1G-GTE only running for ~5 minutes Wed, 01 September 2004 02:19 Go to next message
While I had the 1g-gte in the bay, all those weeks ago, We managed to get it running. While it was running, it idled high... I assume this was the cold idle doing it's job nicely. After some time it just lost power completely... cut out. We tried cranking it but nothing. We then left it to let it cool off, sure enough, it ran again!
What could cause this? Disconnected temp sensor? ECU not getting correct power? My stupidity for not checking if the alarm was disabled? (though I think the last one is unlikely... it used to just not start if the immob was enabled)
Since I haven't had the engine to fiddle with i'm still wondering what the problem is.
indian
south east - melbourne
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 02:30 Go to previous messageGo to next message
turbo timer malfunction maybe
soaringmik
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 02:31 Go to previous messageGo to next message
it could be temp related, did you have water in it?
My old 1ggt would cut out when it got to hot i.e 38 deg, idling for 5 mins.
Just a suggestion
HyDrA
Adelaide, SA
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 02:34 Go to previous messageGo to next message
Yeh had water in it...
I suspect it's the temp sensor.
indian, I dont have no turbo timer!
EvilJack
Sutho/Hills NSW
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 03:10 Go to previous messageGo to next message
you may have a leak somewhere
also up on the throttle body there is a screw to adjust the idle, maybe play with that a bit
HyDrA
Adelaide, SA
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 03:14 Go to previous messageGo to next message
It doesn't seem to be a leak (air leak)... I checked for that.
We tried adjusting the idle screws too, no help.
There is a screw on the throttle body for idle adjust, but there is also a screw on the AFM... what function does it serve?
If the ECU wasnt getting power from say, BATT or B1 or B2 would it do something like this?
gold28
Madrid - Spain
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 03:16 Go to previous messageGo to next message
Could be lack of fuel. Are you running a surge tank, is it plumbed up correctly and both pumps working properly
EvilJack
Sutho/Hills NSW
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 03:20 Go to previous messageGo to next message
i wouldnt touch the AFM unless its on a dyno.
It controls your fuel mixture
im guess its an intank setup having a 1g-ge in it standard?
[Updated on: Wed, 01 September 2004 03:21]
HyDrA
Adelaide, SA
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 03:25 Go to previous messageGo to next message
No surge tank... car came with a 1G-GE, so it was a bolt in job.
All fuel plumbing is correct, and filtered!
Looks like i'm going to get a dyno tune done... We might well have screwed it in and out a bit in order to figure out what was going on Smile
Fuel pump is getting power, and pumping fuel. Fuel is making it to the fuel rail.
Really need to get the engine back so I can further diagnose this! It's bugging me!
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 03:28 Go to previous messageGo to next message
Sounds like none of the injectors are hooked up or they are all blocked.
Sounds like it was just running on the CSI.
The CSI is designed to work when the water temp is below a set amount.
Once the water temp is above that, it completely shuts off.
Sounds like this is whats happening.
EvilJack
Sutho/Hills NSW
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 03:29 Go to previous messageGo to next message
might be worth checking for error codes ??
HyDrA
Adelaide, SA
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 03:42 Go to previous messageGo to next message
There were no error codes.
Injectors were powered, BUT i'm not sure if they were firing. It is possible that they are blocked.. but all of them blocked?
So many questions... I can't wait to get the engine back so I can work out whats going on Smile How much should I expect to pay to have injectors cleaned? Might call FnM and get them to do it for me as a part of the rebuild. Could still be power related I guess.
Looking over the wiring, the ECU has several + power sources... if one of these wasn't getting any positive power, then would it be possible that one of the circuits wasnt working, say the injector switching circuit?
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 06:01 Go to previous messageGo to next message
Yes, get them cleaned, definately
I paid 16.50 each injector, inlcuding new seals.
Injector's are earth switched inside the ecu.
Fattony
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 17:43 Go to previous messageGo to next message
If the car is idling fine when its cold as you stated above, just high IT IS NOT YOUR INJECTORS. Your injectors work when the car is cold, if you dont belive me try unplugging one of them when the car is cold and idling and see wat happens. One possible thought is that your temp sensor that the ecu uses once its done with the cold start temp sensor might be fuggered, this is a green sensor under the dizzy, the brown one is for cold start, hook up a multi meter and actually see if the sensor is getting some signal.
Cheers Adam
YelloRolla
On your mum!
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 21:42 Go to previous messageGo to next message
I had a problem just as you describe and it turned out to be the injectors weren't firing just as cruzsida said. I tested the injectors by using an injector plug (with the wire clip removed) and a transformer. By powering each injector with the engine off I was able to hear if they were clicking. A simple knock on the injector body with a big screwdriver gets them going.
HyDrA
Adelaide, SA
Re: 1G-GTE only running for ~5 minutes Wed, 01 September 2004 22:02 Go to previous messageGo to next message
Fattony, I hope you are right Smile
Just to help everyone out, when it was idling, we could rev it (though we didnt rev it much since we had no tacho hooked up at the time). I suspect the injectors were fine (afaik they were firing since we tested them using a 1G-GE injector)
Now that you mention it Fattony, that green sensor... I have the strangest feeling that I said "hey, the green sensor is unplugged" as I pulled out the engine... Maybe that was it Smile
Time will tell it would seem... engine might well be back this weekend.. and pigs might fly.
Fattony
Re: 1G-GTE only running for ~5 minutes Thu, 02 September 2004 07:27 Go to previous messageGo to next message
Well from what i can gather that you say the motor ran fine (i.e firing on all 6 cyls) for the cold start period and that it still does when its cold, just that the car doesnt work when the cold start disengages. As i said the brown water temp sensor is for cold start and the green one is the one that the ecu uses to read water temp. If your green coloured sensor is dodgy or not plugged in, this might be your problem though i have never ran a 1g without that sensor plugged in so i aint sure if it is used all the time or just when the engine is not running on cold start enrighment.
HyDrA
Adelaide, SA
Re: 1G-GTE only running for ~5 minutes Thu, 02 September 2004 08:18 Go to previous messageGo to next message
I dont suppose one of you 1G owners would like to try something for me would you? Unplug the green sensor plug... I wanna know if that causes you any trouble straight away or after it warms up and disengages the cold start injector Razz
Fattony
Re: 1G-GTE only running for ~5 minutes Fri, 03 September 2004 10:24 Go to previous messageGo to next message
Look if i can get my car running again this weekend hopefully, i shall do this for you and let you know, but no guareentes tough i am a very lazy person LOL
Cheers Adam
HyDrA
Adelaide, SA
Re: 1G-GTE only running for ~5 minutes Fri, 03 September 2004 10:47 Go to previous messageGo to next message
Thanks! Razz
HyDrA
Adelaide, SA
Re: 1G-GTE only running for ~5 minutes Mon, 06 September 2004 02:25 Go to previous message
Any luck Fattony??
I didnt get my engine back... might get it back this week! Laughing
Oh well, gave me a chance to look at the wiring a bit more Rolling Eyes
Previous Topic:battery relocation... help from people who've done it!
Next Topic:3sgte warning light codes
Current Time: Sun Oct 25 14:46:31 UTC 2026
Total time taken to generate the page: 0.089768886566162 seconds
