Toymods » Tech & Conversions » What does this relay/box do??
ta2272
icon3.gif  What does this relay/box do?? Wed, 01 September 2004 05:52 Go to next message
Hey i have in my engine bay and i want to know what it is im uessing it is a relay but what for, the car is a ta22 celica and it is on the drivers side closest to the headlights it has 6 pins and it factory, thanks.
Jason
sideshow
Re: What does this relay/box do?? Wed, 01 September 2004 08:22 Go to previous messageGo to next message
does it have
thick white wire
yellow wire
black/ yellow wire
white / red wire
black wire
if it has the above coloured wires i think theyre correct colours then its the voltage regulator for the alternator
juzzo84
Hornsby, N.S.W
Re: What does this relay/box do?? Wed, 01 September 2004 08:31 Go to previous messageGo to next message
the reg's in the 22's are usually on the passenger side!!
justin
ta2272
Re: What does this relay/box do?? Wed, 01 September 2004 11:20 Go to previous messageGo to next message
No it has 6 different green coulerd wires with stripes on it it runs to the blink/highbeem swith in on your steering coolum.
Fattony
Re: What does this relay/box do?? Wed, 01 September 2004 17:34 Go to previous messageGo to next message
ta2272 wrote on Wed, 01 September 2004 21:20
Havnt you just answred your own question
ta2272
Re: What does this relay/box do?? Wed, 01 September 2004 23:56 Go to previous messageGo to next message
i know were the wires go but what does the box do,
Azrael
Crapberra
Re: What does this relay/box do?? Thu, 02 September 2004 02:49 Go to previous messageGo to next message
I've checked through my wiring diagrams and all I can find in regards to green wires going to the lights is for your indicators; headlights and high beams all have red wiring (factory). Unfortunately my diagrams are for '73 onwards, although owning a '72 myself I do not have any such relay/switch/box and my wiring matches the diagrams too. Can you give any more specifics as to where each individual wire goes and what colour stripes they have??
Bugman
Re: What does this relay/box do?? Thu, 02 September 2004 03:12 Go to previous messageGo to next message
/me slaps forehead.
Fattony
Re: What does this relay/box do?? Thu, 02 September 2004 07:28 Go to previous messageGo to next message
/me slaps Bugman around a bit with a large trout
ta2272
Re: What does this relay/box do?? Thu, 02 September 2004 10:57 Go to previous messageGo to next message
The green wires do not go to the headlights they just go to a little box which looks like a realy near the drivers side headlights.
I will have to check the coulers of the strips but the 6 of them are all green they all go to the one place which is into the cabin into the wiring loom which goes to the blinker/headlight switch.
My blinkers arnt working atm so im trying to find out if this little box could be the problem the flasheer unit still works and i have tried another one still worked, aswell the hazrads also work.
BradW
Bottom of the hill, Sydney
Re: What does this relay/box do?? Thu, 02 September 2004 13:45 Go to previous messageGo to next message
Do you have an ignition supply at the flasher can?
Brad
ChuckLandwehr
Re: What does this relay/box do?? Fri, 03 September 2004 07:16 Go to previous messageGo to next message
Hi mate, I have 2 Ta22's sitting in the driveway, both fully functional. The Plug with the green wires simply has a corresponding type connector with 2 wires looped back into the plug. What it does? no idea, sorry. But I am sure it has ZIP to do with your indicators. I have just fixed, an indicator problem, with same symptoms as you have. It turned out to be a bad earth from the flasher can.
regards Chuck.
ta2272
Re: What does this relay/box do?? Fri, 03 September 2004 07:43 Go to previous messageGo to next message
But chuck my hazrads work anytime al the time my blinkers havnt made a flash in the last 2 weeks, did you have the same symptons.
Jason
ta2272
Re: What does this relay/box do?? Sun, 05 September 2004 23:19 Go to previous messageGo to next message
i Have also found when i turn hazards on this rela/box whatever click also in the engine bay with the hazards.
Jason
ChuckLandwehr
Re: What does this relay/box do?? Mon, 06 September 2004 07:58 Go to previous messageGo to next message
Damn these forums being down all weekend! Yup hazards Worked! therefore can is working. It is not unusual for the contacts at the indicator switch to fry while the alternator is under heavy load, and slightly frail. Example sitting at stop lights, foot on brake, lights on, heater on, wipers and indicators on, I fried the contacts in the indicator switch. (the weakest part of the system failed) All I can say is check your circuits as per the wiring diagram. Even a fairly basic diagram from a Haynes manual should get you out of trouble.
regards Chuck.
ta2272
Re: What does this relay/box do?? Mon, 06 September 2004 13:08 Go to previous message
Ok thanks for this i have also spoken to someone elses about the problem they said that because my hazrads are working there is a problem in the switch , i was tol make anothere earth from the switch and see if they work, problem is there is 6 pins in the blinker plug what are all thses.
Previous Topic:1JZ radiator hoses
Next Topic:2t constantly stalls. why?
Current Time: Sun Nov 1 02:50:45 UTC 2026
Total time taken to generate the page: 0.0067160129547119 seconds
