Toymods » Tech & Conversions » RAxx heater causing backcharge
White Rabbit
Maitland, NSW
RAxx heater causing backcharge Wed, 01 September 2004 07:51 Go to next message
Just seeing if anyone has had an RAxx celica that has had this problem. If i put on the heater - the charge light begins come on. I guessing a bad earth??? Any ideas or suggestions would be great.
munki
Gold Coast
Re: RAxx heater causing backcharge Wed, 01 September 2004 09:12 Go to previous messageGo to next message
mine has that too!
except if i put the fan on past 2
no idea what it is from tho sorry would like to know though. mine also only does it when the parkers/lights are on.
Re: RAxx heater causing backcharge Wed, 01 September 2004 09:34 Go to previous messageGo to next message
munki wrote on Wed, 01 September 2004 17:12
mine has that too!
Either a faulty wire somehwere, or your charging system sucks.
Check the connections on the alternator
Check the connections on the battery
And the earth to the block.
munki
Gold Coast
Re: RAxx heater causing backcharge Wed, 01 September 2004 11:12 Go to previous messageGo to next message
im thinking a short somewhere near the switches or something because it has happened with 2 engines with 2 separate alt etc.
the charge light doesnt come on very much at all it probably ocmes on during the day but i can only notice it during the night because its so dull
M.W.P.
Rocky Mountains, Canada
Re: RAxx heater causing backcharge Wed, 01 September 2004 16:31 Go to previous messageGo to next message
Itll be a bad ground or power connetion in the dash or on the battery.
If turning your headlights on doesnt make the alt light come on, its not an alternator/regulator problem.
[Updated on: Wed, 01 September 2004 16:32]
Re: RAxx heater causing backcharge Wed, 01 September 2004 23:15 Go to previous messageGo to next message
Yeah I vote bad earth too. It's easy enough to check if the charging system is the problem though, just put a multimeter on the battery while the engine is running and heater is on; as long as the voltage is well over 12v (ideally more like 13.5v) it's all good. Smile
wayne
Re: RAxx heater causing backcharge Thu, 02 September 2004 00:16 Go to previous message
I recently had electrical problems with my RA28. My charge light would come on when I turned the fan on and all my gauges were reading incorrectly. I found the problem to be an old rusty fuse in the fuse box which fed the whole dash.
Try all the fuses and make sure they are firmly in place as well.
Previous Topic:Which turbo?
Next Topic:Piggyback computers for Toyota ECU
Current Time: Thu Oct 29 02:48:25 UTC 2026
Total time taken to generate the page: 0.020532846450806 seconds
