Toymods » Tech & Conversions » 100kw bottom end swap
rxjohn
Melb VIC
100kw bottom end swap Thu, 02 September 2004 01:13 Go to next message
ive got an ae82 4age big port 86 kw engine, i know you can swap to the 100kw bottom end,(stronger and higher comp)and use the big port head, what is required to do it,any modifications required? will my acc all fit up, will my flywheel bolt on?
._T_.
Re: 100kw bottom end swap Thu, 02 September 2004 04:23 Go to previous messageGo to next message
use the search function - this was covered (yet again) about 2 weeks ago.
rxjohn
Melb VIC
Re: 100kw bottom end swap Thu, 02 September 2004 05:08 Go to previous messageGo to next message
apparently it all bolts up, i know that but:
just block oil return in block? anyone done this
does the 86kw flywheel bolt up?
[Updated on: Thu, 02 September 2004 05:09]
._T_.
Re: 100kw bottom end swap Thu, 02 September 2004 07:12 Go to previous messageGo to next message
block off the return drain - bit of alloy in the hole with a hose clamp works.
flywheel bolts up
T
rxjohn
Melb VIC
Re: 100kw bottom end swap Thu, 02 September 2004 21:50 Go to previous message
Thanks,
will start on it this weekend.
Previous Topic:1JZ MX83 Cressida.... questions... ??
Next Topic:MA61 Dash Swap
Current Time: Thu Oct 29 01:21:01 UTC 2026
Total time taken to generate the page: 0.027534008026123 seconds
