Toymods » Tech & Conversions » How to wire up an antenna on a '90 GT4
Sledge
How to wire up an antenna on a '90 GT4 Thu, 02 September 2004 03:16 Go to next message
I've recently put a kenwood deck (KDC-5018) into my '90 GT4 and i'm having trouble getting the electric antenna to go up...i tried connecting the antenna wire to the black/red stripe wire which i believed was the correct one but nothing happened..any ideas? It used to have an AKAI deck in there but the antenna didn't work then either..
[Updated on: Thu, 02 September 2004 03:17]
ra23celica
Re: How to wire up an antenna on a '90 GT4 Thu, 02 September 2004 03:57 Go to previous messageGo to next message
First things first - test the antenna separate from your deck.
Its drivebelt may be broken, or jumped off the cog or the motor has failed.
Sledge
Re: How to wire up an antenna on a '90 GT4 Thu, 02 September 2004 04:42 Go to previous messageGo to next message
I'm no electrician...how do i test it? Smile
ra23celica
Re: How to wire up an antenna on a '90 GT4 Thu, 02 September 2004 07:24 Go to previous message
Get a wiring diagram for your car.
Find the two wires that provide power and earth to your antenna.
Put 12V to the power (use a battery charger or your own battery),
and connect the earth to earth and see/hear if the electric motor is whirring away.
If it is and no up/down, disassemble and check the drive belt.
If no whirr you would suspect the electric motor is kaput.
Previous Topic:HELP! *SA63 ALTERNATOR PLUG ID*
Next Topic:SV21 Camry electronics help, re: accessories fuse box..
Current Time: Thu Oct 29 14:43:19 UTC 2026
Total time taken to generate the page: 0.041856050491333 seconds
