Toymods » Tech & Conversions » 1jz auto shift kit help!!
quick 6
Brissy
1jz auto shift kit help!! Thu, 02 September 2004 03:52 Go to next message
he guys. just got a manual shift ox to go on my 1j ut i cant for the life of me figure out how to wire it up. It came from MV automatics so if anu of you have used one before and you can help it would e appreciated.
Thanks rolly.
a wireing diagram of the auto box loom would be great.
Celia-Sue
Re: 1jz auto shift kit help!! Thu, 02 September 2004 07:32 Go to previous messageGo to next message
What car was your autobox from again?
The soarer guys on www.alsc.com.au are right into the MV shift kits and I'm pretty sure I've seen some how-to photos there a few years back.
MS-75
Re: 1jz auto shift kit help!! Thu, 02 September 2004 10:57 Go to previous messageGo to next message
Hi mate, I wrote an instruction sheet for mike on fitting the shift boxes, so I'll dig it up at work tomorrow and send it to you if you like. As some background, is this a conversion or a soarer?
Also, to make the hookup a bit easier, do you have a multimeter?
Sean
Chris Davey
sunny coast, qld
Re: 1jz auto shift kit help!! Thu, 02 September 2004 11:21 Go to previous messageGo to next message
Just to clarify, you are talking about the electrical device that makes the auto "tiptronic" right so you can use an aftermarket computer with the auto?
Ms-75: If i remember correctly, he has a 1jz in a VSish model commodore, so a conversion. I am sure he will answer though Razz
quick 6
Brissy
Re: 1jz auto shift kit help!! Thu, 02 September 2004 12:01 Go to previous messageGo to next message
yes its in a vs commo. got it mostly sorted tonight..
dramas now are. BIG oil leak form some where.
It seams to be reverse pattern. eg third is where first should be. and vise versa.
as soon as the car hits about 16psi it feels like it just slips its ass off.
Any ideas guys.
MS-75
Re: 1jz auto shift kit help!! Thu, 02 September 2004 21:56 Go to previous messageGo to next message
Hi there mate-acouple of questions for you.
Are you using the commodore shifter?
Is the trans wired up to the car in any way?
Is there currently ANY power (12V) going to the transmission at all?
IF the trans is not connected electrically in any way, it will only shift 1,3,4. It will not select 2nd gear at all.
Be careful driving it like this as you can damage the trans by over heating it.
Also, make sure the throw of the commodore shifter and the throw of the lever on the toyota box are compatible. If not, re-drill the shifter or the box lever to suit.
Send me your email address and I'll send the sheet to you.
Sean
quick 6
Brissy
Re: 1jz auto shift kit help!! Fri, 03 September 2004 13:00 Go to previous messageGo to next message
thanks for all the help guys.
yes have power to the trans but seams i had the wires for the two solionds the wrong way around. should have that sorted tomorrow. I am not using the commodores shifter as it is a very GAY piece of shit. instead i have a b and m pro rachet sitting in its place.
Looks like i have sorted all the problem except that the wastegate now wants to sit on the steering rack. (not real good).
Ill let you all know how i go with it tomorrow
Rolly
Rolly@autostyles.com.au
Bentt
Re: 1jz auto shift kit help!! Mon, 06 September 2004 05:59 Go to previous messageGo to next message
How'd you go Roland???
I dug my info up but never got a call from you Razz
Sounds like you are having some sucess anyways Smile
quick 6
Brissy
Re: 1jz auto shift kit help!! Mon, 06 September 2004 07:30 Go to previous messageGo to next message
ok the only problems i have now are that i can work out the wires for the solinoids, theres 3 or them but from what i can see i only need 2 or them hooked up. Im guessing thats why it just slips away as soon as i hit anything over 15psi.
Any ideas on this Ben.
Rolly
Bentt
Re: 1jz auto shift kit help!! Mon, 06 September 2004 23:16 Go to previous message
Roland...
Gimme a yell tonight mate... I'm pretty sure the solenoid has only two wires... I have the complete Soarer wiring diag on my laptop...
Previous Topic:Which Oil?
Next Topic:carby cleaner problems
Current Time: Thu Nov 19 15:56:47 UTC 2026
Total time taken to generate the page: 0.0054230690002441 seconds
