Toymods » Tech & Conversions » 2t constantly stalls. why?
TA-022
Glenmore Park, NSW
2t constantly stalls. why? Thu, 02 September 2004 12:35 Go to next message
Over the last 2-3 weeks idle began to bounce from 800-1000rpm. Have it set at 900.
Then this week set at 900 idle the variation is that bad it actually stalls. I have increased idle to 1700 rpm to compensate so i can do the 5min drive to work and back each day.
Fuel is good....fuel filter brand new since problem occured...new spark plugs/leads/coil, Rebuilt and cleaned carby.
what im thinking is a valve problem of some sort?
any other possibilities before i pay for a mechanic to check it out?
Nathan
Re: 2t constantly stalls. why? Thu, 02 September 2004 13:03 Go to previous messageGo to next message
Have you checked the inlet manifold bolts to make sure they are tight?
TA-022
Glenmore Park, NSW
Re: 2t constantly stalls. why? Fri, 03 September 2004 07:46 Go to previous messageGo to next message
no but i will tonight.
anything else it could be?
its fine once you accelerate its just when the clutch is in or when in nuetral.
Nathan
Karl_skewes
New Zealand
Re: 2t constantly stalls. why? Fri, 03 September 2004 10:16 Go to previous messageGo to next message
sounds like an air leak somewhere.
check all your pipes, and fpr hose.
fade-e
Re: 2t constantly stalls. why? Fri, 03 September 2004 10:49 Go to previous messageGo to next message
what you can do is while car running, accelerate so it doesnt stall, cover carby properly and our water around the carby base and intake mani and check for bubbles. if you see bubbles then air leak.
have you checked compression? especially on 1st cyl. when you checked the plugs none had oil or any liquid residue?
TA-022
Glenmore Park, NSW
Re: 2t constantly stalls. why? Mon, 06 September 2004 13:00 Go to previous message
fade-e wrote on Fri, 03 September 2004 20:49
tightened intake manifold - was a bit loose - changing for new gasket this weekend as precaution.
compression test was even across all cylinders.
problem turned out to be i left the hose clamp off the pcv valve Very Happy just nevr noticed it till my father in law pointed it out. Always takes a fresh set of eyes.
replacing all air hosess this weekend to be safe as there is still a slight jumping in idle but not enough to stall or warrant a 17-1800 rpm idle to stay alive.
thanks heaps guys.
on another note .... tapping that increases with rpm's? tappet adjustment? or possibly timing chain tension?
Nathan
[Updated on: Mon, 06 September 2004 13:06]
Previous Topic:What does this relay/box do??
Next Topic:HELP! ALTERNATOR IDENTIFICATION!
Current Time: Sat Oct 31 08:42:09 UTC 2026
Total time taken to generate the page: 0.029310941696167 seconds
