Toymods » Tech & Conversions » oil catch can
djbourboncan
oil catch can Fri, 03 September 2004 04:36 Go to next message
anybody on here using a oil catch can for extreme high oil pressure ??
i have a k&n breather filter on the rocker cover but there is still too much pressure under hard acceleration
ive been told that you have two inlets from rocker covers to can and base of can goes to sump and the hose at the top goes to inlet manifold to suck clean air through, this helps to relive crankcase pressure etc.....but what stops oil from being sucked straight into the inlet manifold
Bugman
Re: oil catch can Fri, 03 September 2004 05:30 Go to previous messageGo to next message
do a google search. it'll have baffling and some form of filtration to collect the oil particals and make them drop to the bottom of the can.
djbourboncan
Re: oil catch can Fri, 03 September 2004 06:02 Go to previous messageGo to next message
thanks, i know what involved in doing it, just wanted to see if anybody is running one and how do they go with oil getting sucked into the intake
the idea of the can is to have a mesh inside to stop the oil from reaching the top, but that dosnt stop it only inhibits it slightly, so i am just going to run a bigger return oil line to the sump
monkeymajik
Re: oil catch can Fri, 03 September 2004 08:45 Go to previous messageGo to next message
I wouldnt return it to the sump. My can collects alot more water than oil, from condensation, you dont want that getting into your sump.
Alainve
Newcastle NSW
Re: oil catch can Fri, 03 September 2004 08:57 Go to previous messageGo to next message
monkeymajik wrote on Fri, 03 September 2004 18:45
what he said. i was using an old air con dryer reciever as a catch can in my old car and it caught more water than oil.
djbourboncan
Re: oil catch can Fri, 03 September 2004 12:13 Go to previous messageGo to next message
so what do you do with the excess oil then ?...disconnect the hoses and empty the lot ?...how often once a week ?
how is yours setup ?
Danners
Central Coast, NSW
Re: oil catch can Fri, 03 September 2004 12:19 Go to previous messageGo to next message
Ditto, i've only just installed mine and was surprised to find quite a bit of condensation drip out of it when emptied
Dan
feral4mr2
Bundaberg, Qld.
Re: oil catch can Fri, 03 September 2004 13:29 Go to previous messageGo to next message
i made mine like on this thread.
djbourboncan
Re: oil catch can Fri, 03 September 2004 13:59 Go to previous messageGo to next message
my idea is this, with the bottom of the can leading to the sump
ive been told the top breather should be removed and connected to the inlet manifold so it sucks through to help relieve crankcase pressure more
http://www.streetcommodores.com.au/forum_3/attachment.php?attachmentid=14268&stc=1
Alainve
Newcastle NSW
Re: oil catch can Fri, 03 September 2004 14:04 Go to previous message
i emptied mine every 2-3 weeks but monthly should be fine.i kept the drainings to check what they were exactly and found it collected less than 100ml in over 6 months total on a tired old 2T-c.
and yes comnnect it back to your inlet it makes the thing work better and keeps your engine bay cleaner
Previous Topic:help not going into gear
Next Topic:2tg question..... possibly stupid
Current Time: Sat Nov 21 00:25:10 UTC 2026
Total time taken to generate the page: 0.0070199966430664 seconds
