Toymods » Tech & Conversions » help not going into gear
driftae86
perth
help not going into gear Fri, 03 September 2004 11:10 Go to next message
hey guys,
can someone tell me why sometimes i cant shift my car into gear?
sometimes when im waiting at the lights i put it into neutral and when i want to put it into first - it just wont go.
eventually i "convince" it to go in and then im off.
can someone tell me why this happens?
is my gearbox stuffed?
ive got a 4age sprinter
YelloRolla
On your mum!
Re: help not going into gear Fri, 03 September 2004 11:17 Go to previous messageGo to next message
Clutch - either needs adjusting or it is stuffed.
driftae86
perth
Re: help not going into gear Fri, 03 September 2004 11:24 Go to previous messageGo to next message
yeah, makes sense.
sometimes when im sitting at the lights with the clutch in, in first gear and without the brake on, the car rolls forward really slowly. Sad
must be the clutch.
im glad its not my gearbox Smile
ae95
Re: help not going into gear Fri, 03 September 2004 11:27 Go to previous messageGo to next message
could be worn synchro in the gbox too
Fattony
Re: help not going into gear Fri, 03 September 2004 11:49 Go to previous messageGo to next message
Your problem is that your clutch is not disengaging properly.
There could be a few things causing this, the easiest solutions would be that the clutch needs bleeding, or adjusment. Other than that your slave or master cyl could be shot or the diaphram on the pressure plate is fuggered.
Cheers Adam
allencr
tallahassee FL usOFa
Re: help not going into gear Fri, 03 September 2004 14:50 Go to previous message
going into reverse always grinds a lot doesn't it?
then - clutch drag - bad pressure plate, bad clutch disk, or bad/rusty input shaft splines - if it isn't the hydraulics.
how much free play?
if it doesn't drag & have trouble with reverse, it's just the syncro hub teeth butting up against each other, and just lightly easing up on the pedal will move the transmission input shaft enough to let you push it into gear.
Previous Topic:need some help! 7m gte
Next Topic:oil catch can
Current Time: Sat Nov 21 00:13:42 UTC 2026
Total time taken to generate the page: 0.0059869289398193 seconds
