Toymods » Tech & Conversions » Titanium conrods and cycle fatigue
Titanium conrods and cycle fatigue Sat, 04 September 2004 01:35 Go to next message
What I have read suggests that it is very good, but then I have heard stories that it isn't (although it is better than aluminium).
Apparently the usual alloy for Ti conrods is Ti 6-4 (6Al, 4V - I presume this refers to the amount of aluminium and vanadium in the alloy).
Do those in the know wish to comment?
shinybluesteel
melbourne
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 01:05 Go to previous messageGo to next message
comment on what?
i cant really comment on the alloy composition, but i know that the later honda NSXs use titanium con-rods.
i remember something about titanium not being so good in areas of cyclic fatigue (akin to aluminium)in one of my engineering electives, it is definately not as good as steel.
are you getting the rods custom made? are just normal forged rods unsuitable for some reason?
ed_ma61
Lost in the K hole
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 01:07 Go to previous messageGo to next message
steel = heavy = rotational intertia - hence the desire to go Ti
wheres stewy Confused
ed_ma61
Lost in the K hole
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 01:13 Go to previous messageGo to next message
btw dave - we used to build xc race bikes out of 6AL 4V, lights as shit, with a very nice natural damping quality to the frames - far superior to chromoly steel.
and whilst we never had a fatigue related failure in any component or weld, ALL major manufactueres steered WELL away from building any of the downhill bikes out of Ti - FAR too punishing use. for those odd custom DH Ti bikes that did pop up - they all broke.
totally anecdotal, and far too many factors at play to say why these bike broke (as did many many 7075 T6 frames, Easton frames, and carbon fibre/thermoplastic frames (ugghhh!!)).
best frames ever were reynolds cromo, or 4130 cromo
food for thought
Lachie
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 02:03 Go to previous messageGo to next message
I suppose the first thing so say, is that all fatigue is caused by cycles, as this creates fluctuating stresses in the part that cause small cracks or manufactring defects to move through the part, causing fatigue faliures.
As far as the fatigue limit (number of cycles) of titanium conrods compared with aluminium or steel, it depends on the tensile strenght or tensile stress (stress that has to be applied before the material will break) of the matrerials. Generally the higher the tensile strenght, the higher the fatigue limit is.
I would suspect that titanium conrods would be much better then aluminium as I suspect the particular alloy would have a higher tensile strenght. However, I am not familar with this particular alloy and couldn't be sure without doing some research that I really don't have time for (sorry!)
Steel (depending on the grade) is still probably better...
The surface finish of the part, manufacturing and the design have alot to do with fatigue. Poor machining, deep scratches, sharp corners and manufacturing defects can all lead to fatigue cracks and ultimately failure.
Hope that helps!
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 02:20 Go to previous messageGo to next message
All my reading in the last week would suggest that Ti is way better than aluminium and from what I can gather possibly better than steel.
Where it wins out majorly is strength for weight compared to steel. Expense seems to be the limiting factor.
I suppose the question I really want answered is, "Will a Ti rod be able to tolerate 5000+ ft/min average piston speed?" I suspect that is dependent upon more things than just rod composition so there is probably no simple yes or no answer.
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 02:32 Go to previous messageGo to next message
Lachie wrote on Mon, 06 September 2004 12:03
Just searching thru the matweb database of materials and it would appear that Ti-6-4 has a similar tensile strength compared to 4340 steel (what most billet conrods are made of).
Thanks again....all food for thought.
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 02:36 Go to previous messageGo to next message
Don't the current crop of Porsche GT3 and Ferrari 360 GT Race/Road cars use titanium conrods? Surely if they can meet a company like Porsche's reliability standards yet perform so reliably on a track they should be up to the task?
Bugman
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 03:03 Go to previous messageGo to next message
and titanium is nice and cheap Smiley =
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 03:14 Go to previous messageGo to next message
justcallmefrank wrote on Mon, 06 September 2004 12:36
That's all well and good, but I'd want to know what anti-galling treatment the slide faces of the big and small surfaces have had. I'd dare say it's a bit fancier than something an aftermarket conrod manufacturer is going to provide. Also we don't know what alloy they are using. The average piston speed is easy enough to find out and given the F360's 79mm stroke and 8500 rpm redline, this works out to a maximum average piston speed of about 4400 ft/min.
[Updated on: Mon, 06 September 2004 03:17]
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 03:28 Go to previous messageGo to next message
True that, but its food for thought. Surely around the net there has to be some information about their composition.
ed_ma61
Lost in the K hole
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 03:32 Go to previous messageGo to next message
i have a suspicion that youll find, as with everything, its going to be a compromise. you want 10,000 rpm and 5000ft/min peak velocities (and god knows what acceleration forces at TDC BDC) then stuff isnt going to last...
i hate compromises No No No
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 04:17 Go to previous messageGo to next message
ed_ma61 wrote on Mon, 06 September 2004 13:32
i hate compromises
Say "NO" to compromises!
Stupid long stroke 2JZ.....
1JZ gets to have all the fun ....stupid 4000 ft/min at 9500rpm...
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 04:57 Go to previous messageGo to next message
ed_ma61 wrote on Mon, 06 September 2004 11:07
in NZ skiing Razz heh heh...
i don't know if i can help the public knowledge effort much.. Ti is used for 'low to medium temp' jet turbine blades becuase of a few things... strength to weight ratio and creep resistance.. but mostly because of weight. large blade = heavy. stronger material = less material used. less dense material = even less material used.
there are so many factors involved here (piston weight, rpm, heat and processing treatments, geometry, etc etc) that it's hard to give a better answer than "it depends" Wink
decreasing piston weight reduces load at TDC at start of intake stroke, and that will increase the life of any rod.
as Ed said... at that rpm, stuff isn't going to last long... hopefully it will last "long enough" Very Happy
SRacin
Christchurch, New Zealand
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 05:06 Go to previous messageGo to next message
[Updated on: Mon, 06 September 2004 06:40]
510rob
Vancouver
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 06:04 Go to previous messageGo to next message
If you are planning to run a high horsepower turbo/supercharged motor, don't bother with Ti rods; get some 4340 rods and spend the money on something else that will actually make more power...
On the other hand, if you are trying to win some specific class, and the rules allow Ti rods, and your budget allows for their cost, and there is some financial gain to be had in beating the competition, then the use of Titanium rods would be justified...
Titanium itself doesn't really make any "magical" extra power; it lets you drop the mass of the reciprocating assembly, allowing you to "potentially" raise the safe operating RPM of the lower end, but when you have gotten to that point, stresses go through the roof with increases in rpm, as opposed to the moderate increase of stresses induced by more radical levels of charge stratification.
So, if you are going to run Titanium rods, the geometry of the motor better be pretty shit-hot, and the valvetrain better be good for more than 10,000rpm, and all of the other exorbatent costs associated with super-RPM motors... and it's lifespan will be measurable in hours rather than the years available from a moderatly high output turbo/supercharged motor...
As one noted engine builder said, "RPM is an acronym for ruins people's motors!" High RPM is exactly what Ti rods will let you run...
Henn
Rosanna, Melb
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 06:38 Go to previous messageGo to next message
An anecdote told by one of my mechanics lecturers centred around a racer neighbour of his who had problems with some titanium rods because of their extra "stretch".
Given the lower Young's modulus of Ti they will elongate/compress more, especially given the forces produced at high RPM.
I've never done the maths, so cant vouch for the accuracy, but bear this in mind.
Hen
Fattony
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 08:48 Go to previous messageGo to next message
justcallmefrank wrote on Mon, 06 September 2004 13:28
I highly doubt that companies like Porsche would give out the composition of the alloy's used in their conrods, though there may be a disgruntled employee. LOL
Cheers Adam
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 09:20 Go to previous messageGo to next message
Fattony wrote on Mon, 06 September 2004 18:48
Interestingly, it's out there.
Year Component Material Manufacturer Model
1992 Connecting rods Ti-3Al-2V-rare earth Honda Acura NSX
1994 Connecting rods Ti-6Al-4V Ferrari All 12-cyl
1996 Wheel rim screws Ti-6Al-4V Porsche Sport wheel option
1998 Brake pad guide pins Ti grade 2 Daimler S-Class
1998 Brake sealing washers Ti grade 1s Volkswagen All
1998 Gearshift knob Ti grade 1 Honda S2000 Roadster
1999 Connecting rods Ti-6Al-4V Porsche GT3
1999 Valves Ti-6Al-4V & PM-Ti Toyota Altezza 4-cyl.
1999 Turbo charger wheel Ti-6Al-4V Daimler Truck diesel
2000 Suspension springs TIMETAL LCB Volkswagen Lupo FSI
2000 Wheel rim screws Ti-6Al-4V BMW M-Techn. option
2000 Valve spring retainers beta-titanium alloys Mitsubishi All 1.8 l – 4-cyl.
2000 Turbo charger wheel gamma-TiAl Mitsubishi Lancer
2001 Exhaust system Ti grade 2 General Motors Corvette Z06
2001 Wheel rim screws Ti-6Al-4V Volkswagen Sport package GTI
2002 Valves Ti-6Al-4V & PM-Ti Nissan Infiniti Q45
2003 Suspension springs TIMETAL LCB Ferrari 360 Stradale
You'll notice the S2000's gearshift knob is made out of titanium - that has to be factory sanctioned rice. Laughing
Thankyou for the references Stewart.
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 10:23 Go to previous messageGo to next message
Wooh yeah!
SRacin
Re: Titanium conrods and cycle fatigue Mon, 06 September 2004 23:53 Go to previous messageGo to next message
Yeild Strength
Ultimate Strength
True Facture Strenth
Toughness (Mpa root(m)
100%elongatoin
to failure
reduction in area
AISI 4340 1103 1172 1634 110 14 49
ti-6AL-4V 1185 1233 1717 66 16 34
Mechanical Behavhiour of MAterial, Norman E Dowling. table 9.1
Logan
nicked
Re: Titanium conrods and cycle fatigue Tue, 07 September 2004 04:35 Go to previous messageGo to next message
http://www.imeche.org.uk/tribology/pdf/Luo.pdf
That kind of touches on the subject, its actually about surface fatigue for automotive gears. if you could access the references especially number 5 (without paying), they could help be more helpful.
Seems like that particular alloy (and ti alloys generally) have a good fatigue/endurance limit (580 Mpa @ 10^7 cycles), this seems comparable to 4340 - although i can never find the same number twice for that sort of data! The fact that it has an endurance limit is good, means (theoretically) you can keep stressing it to <580mpa forever ( Rolling Eyes ), whereas aluminium alloys the value keeps dropping to zip.
But it seems they do wear pretty poorly under friction, unless treated- which is what that article's about.
That doesn't really answer your piston speed q, but you get that..
its amazing how much fun you can have with other people's problems when you dont want to work on your own Smile
Re: Titanium conrods and cycle fatigue Tue, 07 September 2004 05:44 Go to previous messageGo to next message
the reason you never see the same numbers twice for fatigue related properties is because "it depends".
depends on size of specimen, size of starter notch, load applied, rate of loading, even the time of each loading cycle. to compare data, you would need the EXACT same experimental conditions, and even then, it's difficult to ensure that the starter crack properties are EXACTLY alike...
full title for that article (5) is
TI: Surface engineering of titanium alloys for the motorsports industry
AU: Dong, H; Bell, T; Mynott, A
SO: Sports Engineering. Vol. 2, no. 4, pp. 213-219. 1999
Quote:
AB: Abstract
The ever increasing demands of motorsports has been the main driving force for substituting titanium components for steel in racing cars and engines by virtue of their higher strength to weight ratio. This allows savings in general weight and inertial energy, and allows a more beneficial weight redistribution in the car. However, the poor tribological properties of titanium alloys has restricted such replacement, and the full potential of titanium alloys in racing cars will not be realised until some novel surface engineering technologies have been developed. An innovative surface engineering technique developed by Dong et al. can successfully improve the tribological behaviour of titanium alloys in terms of low friction, high wear resistance and high resistance to scuffing. This has made possible the regular use of titanium components in Formula 1 and Indy cars engines. Furthermore, with the aid of a recently developed predictive contact mechanics model, some novel duplex systems have been designed to meet the challenging demands for the design of high dynamically loaded titanium gears. The duplex treated titanium gears have satisfactorily completed rigorous cam rig tests under a pick-up load of 50 Nm at speeds up to 17000 r.p.m., which could pave the way for the use of titanium alloys in gear boxes. The present paper demonstrates, by way of example, a number of major steps towards titanium designer surfaces. The motorsports industry has recognised the potential of surface engineered titanium components and it is envisaged that the new Millennium will see wide applications of titanium in the motorsports industry. Materials include Ti-6Al-4V.
i should have access, but apparently not from home.
funnily enough i DO have online access to "sports illustrated" tho Laughing
UTS and sydney uni students have access.
nicked
Re: Titanium conrods and cycle fatigue Tue, 07 September 2004 06:00 Go to previous messageGo to next message
hmmm.. not this sydney uni student Confused
when i go into that database logged in as sydney uni it still asksme to cough up $37.75! tells me im not a subscriber.
because i use the uni isp at home, i can go wherever i could go on campus, so it seems we dont subscribe to that. we do subscribe to other journals in the 'ingenta' db though, which is where i found it.
i too have access to sports illustrated though! Very Happy
ed_ma61
Lost in the K hole
Re: Titanium conrods and cycle fatigue Tue, 07 September 2004 06:58 Go to previous messageGo to next message
oldcorollas wrote on Tue, 07 September 2004 15:44
stewy - what database can i find "Sports Engineering" journal under? i can dig it up from here and post it if you can give me some clues
ed
[Updated on: Tue, 07 September 2004 06:58]
ed_ma61
Lost in the K hole
Re: Titanium conrods and cycle fatigue Tue, 07 September 2004 07:09 Go to previous messageGo to next message
bugger....
http://www.ingenta.com/isis/searching/Availability /ingenta;jsessionid=4qqcl3gt6gib3.crescent?pub=infobike://bsc/spe/1999/00000002/00000004/art00032 &targetId=1094540889225
gold28
Madrid - Spain
Re: Titanium conrods and cycle fatigue Tue, 14 September 2004 12:35 Go to previous message
gianttomato wrote on Sat, 04 September 2004 11:35
Yup the Al and V are the aluminium and vandium content in the alloy. 6Al-4V is commonly referred to as commercial grade titanium.
The keys to improved fatigue life are
1. Minimize peak and normal stresses ie reduce revs or reduce piston weight.
2. Remove any crack starters - polish the rod
3. Try and toughen the rod surface to resist cracking. I am not sure about Ti but Ally can be cold worked to improve fatigue cracking.
The advantage in ti rods is more that due to the better strength to weight ratio, you can increase the cross sectional area of the rod and reduce the stress (increase strength) and still reduce the weight. Obviously the ratio of these depends on how long you expect the engine to last.
As someone mentioned earlier, reducing piston weight will have a big effect on what your safe RPM will be. However once again this is a balancing act as it may then struggle with heat dissipation.
Previous Topic:jza70/jzx90 intercooler
Next Topic:Springs & suspension
Current Time: Fri Nov 20 12:11:14 UTC 2026
Total time taken to generate the page: 0.38491010665894 seconds
