Toymods » Tech & Conversions » 4AGZE plugs
Michael P
4AGZE plugs Sun, 05 September 2004 23:17 Go to next message
Does anyone know what plugs should be run in GZE. The standard ones are NGK BCPR6EP-N8 (0.8mm gap) that were fitted to the car from japan. Have been offered BCPR6EP-11 (1.1mm gap). Can anyone tell whether 0.8mm plugs are available or should I just use the 1.1mm ones. These are both platinum plugs by the way. Am I going to have problems if I use the 1.1mm plugs.
TE72_Turbo
Re: 4AGZE plugs Mon, 06 September 2004 10:43 Go to previous message
You would be better off sticking to the 0.8mm gap with forced induction. 1.1 is getting a bit marginal, even with the multi-coil setup.
I think your best bet (and best value) is to buy toyota PK20R8 plugs, they are platinum from NipponDenso, and work a treat in my turbo'd GZE. Very Happy
Phil
Previous Topic:Coolant leaking from pump - why!?
Next Topic:4AGE conversions in ae86's regarding engineering cert!
Current Time: Sat Oct 24 09:42:22 UTC 2026
Total time taken to generate the page: 0.0052361488342285 seconds
