Toymods » Tech & Conversions » How to hi-flow a fuel injector
ed_ma61
Lost in the K hole
icon4.gif  How to hi-flow a fuel injector Thu, 23 May 2002 09:50 Go to next message
seeing as the injector type that i'm trying to get my hands on is being a little ellusive...
how possible is it to hi flow a 182cc injector to say 210cc??
i'm talking to some guys tomorrow about it, but would appreciate any ideas the o' knowledgable crowd here migh have hehehe
ed
Re: How to hi-flow a fuel injector Thu, 23 May 2002 09:55 Go to previous messageGo to next message
Bumping up the fuel pressure is the most obvious way to increase the flow rate of any injector.
ed_ma61
Lost in the K hole
Re: How to hi-flow a fuel injector Thu, 23 May 2002 13:48 Go to previous messageGo to next message
yep, upping the fuel pressure is easy, and will be doing that with a RRFPR.
however, i also want to run larger injectors, and the size im after is hard to find (210's)
the idea is to run the stock 5m ecu, and basically fool it into running 10psi, whilst remaining stoichiometric f/r across the pressure curve. to do this will require (most likely) an adjustable base pres rrfpr, and slghtly larger injectors running at slightly lower base pressure at idle.
a tricky balancing act, yes, but it can be done.
so, back to the point, does anyone know if and how you can increase an injector's flow (from 182-210cc) for a given standard fuel presure? its been suggest to me that it can be done, but... you people have an opinion??
ed
[Updated on: Thu, 23 May 2002 13:49]
Re: How to hi-flow a fuel injector Thu, 23 May 2002 14:49 Go to previous messageGo to next message
Are you after the 210CC injectors, are they the 4AGE ones?
Sorry I cant help on the topic of high-flowing though Cry
ed_ma61
Lost in the K hole
Re: How to hi-flow a fuel injector Fri, 24 May 2002 01:28 Go to previous message
yup, 210cc 4age injectors, blue if anyone has them!!....
Previous Topic:Best lowered springs for a a corolla?
Next Topic:NOS 4AGE !!!!
Current Time: Wed Nov 4 18:51:14 UTC 2026
Total time taken to generate the page: 0.0072197914123535 seconds
