Toymods » Tech & Conversions » max boost on 7MGTE
mkiii
max boost on 7MGTE Sun, 22 September 2002 01:01 Go to next message
What is the maximum boost I can run on a standard 7MGTE with 3" cat back exhaust and air filter? I am running 10psi now and want to turn it up to 14psi but am worried about my head gasket. Any comments or suggestions would be appreciated.
Fattony
Re: max boost on 7MGTE Sun, 22 September 2002 01:09 Go to previous messageGo to next message
Knowing that these engines r prone to head gasket failure suggests to me that if you do intend to up the boost to 14psi that you make sure that the charge air is kept at a reasonable temp, and have the computer tuned to suit the fuel that you use and the mods you have done to the car. This should at least keep the engine from detonation hence causing head gasket failure.
Re: max boost on 7MGTE Sun, 22 September 2002 01:32 Go to previous messageGo to next message
Torque that head down before you think about boosting it any further. After that it's a bit of a gamble, but if it doesn't detonate you might be OK.
jza70-mel
Perth WA
Re: max boost on 7MGTE Sun, 22 September 2002 01:47 Go to previous messageGo to next message
Reg Reimer in Canada seems to have done a bit of work on the head gasket problem
http://www.supras.com/~riemer/sonictech/mk3/mk3_pm tn.html
http://www.supras.com/sogidb/index.php?jumpto=tech center&tech_jumpto=display_techtip&id=13
http://www.supras.com/sogidb/index.php?jumpto=tech center&tech_jumpto=display_techtip&id=7
It seems that a few people have had head gasket problems even with standard boost.
SUPRAGTE
North Sydney
Re: max boost on 7MGTE Mon, 23 September 2002 13:01 Go to previous message
Make sure u run the factory red toyota coolant too to stop corrosion on the head and increase head gasket weakening. Lots of 7mgte with blown head gaskets have been running on aftermarket coolant. You'll also hit boost cut if you tweak much more than 10-12psi.
Previous Topic:removing stickers!
Next Topic:T18 Diff gone noisey - options?
Current Time: Mon Oct 26 13:46:10 UTC 2026
Total time taken to generate the page: 0.044539928436279 seconds
