Classifieds » Miscellaneous » AE82, AE92 4AGE Parts REDUCED FURTHER
djb23_20v
Wollongong
AE82, AE92 4AGE Parts REDUCED FURTHER Sun, 22 September 2002 05:12 Go to next message
Guys,
Prices have been reduced.
All AE82 parts have approx 200k kms use, all AE92 parts have approx 175k kms use. I am based in Wollongong, and I am available only on weekends. You will need to organise parts transport or freight at your own time and expense. All prices are negotiable.
1 off AE92 Red Cover 4AGE engine missing loom, most sensors, sump, oil filter/cooler adapter but has ECU, injectors and injector plugs, fuel rail, starter motor, best for parts - $125
1 off AE92 SX 5 spd g/box - $100
1 pair of AE92 SX drive shafts to suit above g/box - $75
1 pair of AE92 SX hubs with brake calipers and rotors - $75
4 off AE82 Twin Cam 14 in. Alloy wheels - $30
1 off AE82 Blue Cover 4AGE head with cams, valve gear, TVIS system, cam gears - $150
Various other parts such as an AE82 4AGE engine plate, AE92 4AGE engine pipe, AE82 4AGE exhaust manifold with no oxy sensor, AE82 Blue Cover 4AGE dizzy, AE82 Blue Cover 4AGE Flywheel, AE82 Blue Cover 4AGE crank, AE82 Twin Cam Differential assembly, AE82 Blue Cover 4AGE Injectors, AE82 4AGE main bearing caps, AE92 fuse box (damaged), AE82 4AGE water pump and some pipework, brackets for accessories, AE92 4AGZE sump.
Parts are missing nuts and bolts in most cases eg: no flywheel bolts.
Upon sale I will discharge all responsibility for the reliability of these parts.
You can contact me via email on djb23_20v@hotmail.com
Dan
[Updated on: Fri, 08 November 2002 23:42]
CrAiGzEE
south of the big smoke
Re: AE82, AE92 4AGE Parts Sun, 22 September 2002 05:20 Go to previous messageGo to next message
im interested in these
1 pair of AE92 SX front brake calipers and rotors
you wouldnt happen to have a rear set would ya?
Blahnana
Re: AE82, AE92 4AGE Parts Updated Mon, 23 September 2002 03:32 Go to previous messageGo to next message
You have mail
CrAiGzEE
Re: AE82, AE92 4AGE Parts Updated Mon, 23 September 2002 06:09 Go to previous messageGo to next message
no longer need the calipers and rotors as i have just found out that they are the same as ive got atm
free bump!
partyjase
melbourne
Re: AE82, AE92 4AGE Parts Updated Mon, 23 September 2002 06:39 Go to previous messageGo to next message
Are the sx rotors bigger than the standard ae92 ones?
How much do u think it would be to freight to melbourne?
djb23_20v
Wollongong
Re: AE82, AE92 4AGE Parts Updated Mon, 23 September 2002 09:13 Go to previous messageGo to next message
The front brakes are the same for AE92 corollas for all models. The rear brakes are disc on the sx, whereas they are drums on the other models (I think).
Rolla Boy
Club Member
Sydney, NSW
Re: AE82, AE92 4AGE Parts Updated Mon, 23 September 2002 13:16 Go to previous messageGo to next message
Have you got the airbox and pipework to the throttle body to suit an AE92 SX 100kW??? If you do, I want it... Also I want the sensor that plugs into the back of the pipe from the airbox to the throttle body... So yeah, if you have the airbox and it's not damaged at all, I want it...
Singlecam
Blue Mountains
Re: AE82, AE92 4AGE Parts Updated Mon, 23 September 2002 14:41 Go to previous messageGo to next message
What condition are the ae82 wheels in? I assume they are without tyres?
Have you got any panels from an ae82 at all?
macks
Re: AE82, AE92 4AGE Parts Updated Wed, 25 September 2002 10:30 Go to previous messageGo to next message
Quote:
1 off AE92 Red Cover 4AGE engine missing loom, most sensors, sump, oil strainer, oil filter/cooler adapter but has ECU, injectors and injector plugs, fuel rail, starter motor - $250
any details would be appreciated... km, why its out of a car, anything at all.
Cheers Smile
St3ve_AE92
South of Wollongong
Re: AE82, AE92 4AGE Parts Updated Wed, 25 September 2002 12:54 Go to previous messageGo to next message
Whats the condition of the gearbox?? syncros all right??
djb23_20v
Wollongong
Re: AE82, AE92 4AGE Parts Updated Wed, 25 September 2002 12:55 Go to previous messageGo to next message
Singlecam: the wheel don't have tyres, and they are about 200,000km old. They have the usual kerb grazes, but they are not bent or buckled.
Macks: The engine is from my AE92 SX which I recently did a conversion to fit a 4AGZE engine. The engine has approx 175,000km on it, and ran fine before I pulled it out. Like the post says, it is missing the oil cooler system (oil filter mount, sump), and the loom has been pulled to pieces (to assist with 4AGZE wiring). The engine will probably be best suited to someone after parts, like the head say or the block etc.
Hope this helps guys
djb23_20v
Wollongong
Re: AE82, AE92 4AGE Parts Updated Wed, 25 September 2002 12:58 Go to previous messageGo to next message
Steve: The g/box shifts fine, but it is 175,00 kms old. I don't know whether it has been rebuilt as I owned the car for 3 weeks before I fitted the 4AGZE engine/gearbox. Slam changing it would certainly cause the 2nd/3rd change to graunch, but all Corolla g/boxes I've experienced seem to do this.
T.J.
Re: AE82, AE92 4AGE Parts Updated Thu, 26 September 2002 09:03 Go to previous messageGo to next message
Would you be willing to seperate the rear plate of the back of the head if you still had the part,
Steve
bigfreak6@hotmail.com
CrAiGzEE
Re: AE82, AE92 4AGE Parts Updated Wed, 02 October 2002 12:17 Go to previous messageGo to next message
hey man have you got the oil pressure sensor?
if ya have can ya let me know cheers mate
rollaboy
Coffs
Re: AE82, AE92 4AGE Parts Updated Wed, 02 October 2002 12:37 Go to previous messageGo to next message
Is that $50 for each blue top Injector or $50 for all 4???
Rolla Boy
Club Member
Sydney, NSW
Re: AE82, AE92 4AGE Parts Updated Fri, 04 October 2002 09:55 Go to previous messageGo to next message
You have e-mail...
Leighp
NY
Re: AE82, AE92 4AGE Parts Updated Fri, 04 October 2002 10:05 Go to previous messageGo to next message
i think i got u a shaft buyer, what is the condition of em??
djb23_20v
Wollongong
Re: AE82, AE92 4AGE Parts Updated Fri, 04 October 2002 13:45 Go to previous messageGo to next message
Guys,
rollaboy: the injectors are $50 for the four
Leighp: driveshaft boots are not split and the shafts were not making any nasty noises before I pulley them out.
djb23_20v
Wollongong
Re: AE82, AE92 4AGE Parts Updated Mon, 07 October 2002 12:33 Go to previous messageGo to next message
Pics are now available of the parts if required!
shano2
QLD - Sunshine Coast
Re: AE82, AE92 4AGE Parts Updated Fri, 11 October 2002 23:28 Go to previous messageGo to next message
Dan,
DO you still have the Ae101 AC compressor?
Is it off a 20V or GZE??
shano@f1.net.au
Shane
djb23_20v
Wollongong
Re: AE82, AE92 4AGE Parts Updated Mon, 14 October 2002 11:47 Go to previous messageGo to next message
Shane,
Sorry the AE101 AC compressor is a misprint - I no longer have the compressor. Sorry for any inconvenience.
Dan
WOW16V
Glossodia,NSW
Re: AE82, AE92 4AGE Parts REDUCED Tue, 15 October 2002 07:38 Go to previous messageGo to next message
Can you send me a pic of the ae92 engine to my e-mail it's lil_rolla@hotmail.com.I would really like to purchase the engine so i can have some spare parts for mine if i ever need them.But this price drop of yours has come at a bad time.I'm in the process of buying a head off "leighp" on saturday and probably a microtech ecu from snyper as well next week and as a result the cash flow will be stretched for a little while.This will sound harsh but would you take $120,it's all i can really afford to offer,but if your not desperate to get rid of it then just ignore my offer
Cheers Adrian
Rolla Boy
Club Member
Sydney, NSW
Re: AE82, AE92 4AGE Parts REDUCED Wed, 06 November 2002 06:41 Go to previous messageGo to next message
Do you have an Air Conditioning compressor at all??? I need one to suit a 100kW 4A-GE...
[Updated on: Wed, 06 November 2002 06:46]
djb23_20v
Wollongong
Re: AE82, AE92 4AGE Parts REDUCED Fri, 08 November 2002 23:43 Go to previous messageGo to next message
I did have a compressor, but I now need it after a hitch with my Corolla - sorry!
Rolla Boy
Club Member
Sydney, NSW
Re: AE82, AE92 4AGE Parts REDUCED FURTHER Sat, 09 November 2002 05:56 Go to previous messageGo to next message
Just a question for you... At the ends of the driveshafts where the threaded bit goes through the hub, are they different sized on either side??? When I say the threaded bit, I mean the section where you screw the nut on and put the split pin through...
On my car, the diameter of the threaded bit is 18mm on the right hand side of the car...
And, the diameter of the threaded bit is 20mm on the left hand side of the car...
This seems wrong to me and I just want to clear it up as I might need to buy them off ya...
djb23_20v
Wollongong
Re: AE82, AE92 4AGE Parts REDUCED FURTHER Sun, 10 November 2002 00:48 Go to previous messageGo to next message
I've just checked those thread sizes - the threads are around 18.5mm diameter for both driveshafts. I do have both driveshafts if you are interested.
Rolla Boy
Club Member
Sydney, NSW
Re: AE82, AE92 4AGE Parts REDUCED FURTHER Sun, 10 November 2002 07:53 Go to previous messageGo to next message
Cool... I'll get back to you on that one...
Leighp
NY
Re: AE82, AE92 4AGE Parts REDUCED FURTHER Fri, 15 November 2002 00:22 Go to previous message
benny benny benny, new shafties hey???
Previous Topic:SOLD
Next Topic:FS: 4AGE TRD Brass Button Clutch
Current Time: Thu Nov 19 09:36:16 UTC 2026
Total time taken to generate the page: 0.0090470314025879 seconds
