Toymods » Tech & Conversions » Calling all AW11 4agze owners
leaven
Calling all AW11 4agze owners Tue, 07 September 2004 07:33 Go to next message
Can anyone who owns this motor tell where I can get a
thermostat to fit. I have tried toyota but what they are saying is not correct.
feral4mr2
Bundaberg, Qld.
Re: Calling all AW11 4agze owners Tue, 07 September 2004 08:12 Go to previous messageGo to next message
what do toyota tell you?
use 4age one.
leaven
Re: Calling all AW11 4agze owners Tue, 07 September 2004 11:48 Go to previous messageGo to next message
Toyota tell me that a 4age one will work fine but the unit they recommend mounts in a thermostat housing. The one i am after mounts in the back of the water pump between the bottom hose outlet of the pump and a metal pipe that runs along the side of the block that flows to the bottom of the radiator.
The one Toyota suggests is way too big for this. Inside diameter is around 38 mm.
There is no thermostat housing for the bottom hose.
feral4mr2
Bundaberg, Qld.
Re: Calling all AW11 4agze owners Tue, 07 September 2004 12:40 Go to previous message
hrmm, ok.. all the AW11's i have seen whether it be 4age or 4agze have the thermastat in the housing on top of the gearbox.
never heard of one inbetween the water pump and that metal pipe. Confused it goes to the thermastat housing anyways..
if you must mount it there for what ever reason, why not go to a auto parts shop and ask to look at their Tridon thermastat book, it has many thermastats of different diameter and heat ranges. wouldnt be too hard to find the one you are after.
Previous Topic:4agze into a 4afe
Next Topic:battery in the back
Current Time: Mon Nov 23 00:46:33 UTC 2026
Total time taken to generate the page: 0.008173942565918 seconds
