Toymods » Tech & Conversions » ignition
jesseT18
Castle Hill, Sydney
ignition Tue, 07 September 2004 11:35 Go to next message
can a few ppl tell me their thoughts about this setup
i just threw all my good ignition parts together and got this...and dont know how well it will work?
its a bosch GT40 super sports coil
its for a 3t-g...still running a points distributor
http://img26.exs.cx/img26/1431/ignition1.jpg
[Updated on: Tue, 07 September 2004 11:36]
jesseT18
Castle Hill, Sydney
Re: ignition Wed, 08 September 2004 05:52 Go to previous messageGo to next message
anybody?
Re: ignition Wed, 08 September 2004 09:04 Go to previous messageGo to next message
eer... if you have points distributor, what the big yellow thing doing? or is it using the points as a trigger and it drives the coil?
Cyber-punk
Brisbane, QLD
Re: ignition Wed, 08 September 2004 09:17 Go to previous messageGo to next message
thechuckster wrote on Wed, 08 September 2004 19:04
damn
you beat me to it
its either that or its a VERY interesting set up :/
jesseT18
Castle Hill, Sydney
Re: ignition Wed, 08 September 2004 09:47 Go to previous messageGo to next message
yeah i thought it might be interesting...
its just wired up as stock, and the yellow box thing (ignighter?) goes to coil+, coil-, distibutor, earth..
dont know much about this, i havent started it yet so if its gunna blow! tell me!
i thought the yellow box was just like a ignition booster that gives stronger spark? why wouldnt you be able to use that with points distributor?
hemi twofifteen turbo
Re: ignition Wed, 08 September 2004 09:51 Go to previous messageGo to next message
heheehe the yellow box is an igniton iginiter.. It is trigged
by a pickup in an ELECTRONIC distributer.. You need an electronic
distributor.. Don't even turn on the red ign lights as you could
kill the ignitor.
jesseT18
Castle Hill, Sydney
Re: ignition Wed, 08 September 2004 09:54 Go to previous messageGo to next message
hahaha right! glad i checked with u guys!
ill disconnect him before i blow something!
on the hunt for a pointless distributor now!
pointless is electronic yeah? or are these 2 different things?
DAMO
MELBOURNE
Re: ignition Wed, 08 September 2004 10:01 Go to previous messageGo to next message
As said earlier it could be a unit that uses the points to trigger it and gives a transister output to coil. If there is no load on points they will last a long time. There shouldn't be a resistor in the cicuit with electronic ignition. I think the gt40 coil is a 12v job and it will only be getting around 7v with the resistor. Hope that helps.
jesseT18
Castle Hill, Sydney
Re: ignition Wed, 08 September 2004 10:04 Go to previous messageGo to next message
ok thats the stuff i wanna hear, what i do/don't need and how i should wire it properly
so i should ditch the resistor!?
and disconnect the ignitor until i have a elec dizzy?
if its relevant...dad rekens he put it on our old alfa romeo cause it was fowling plugs, cause it had no stem seals
apparently this thing solved the problem...and that had a points distributor!
i wanna come to a safe and good conclusion soon, ill probably be ready to start it up again tomorrow night
(currently has no cam chain tensioner)
keep it coming fellas i really need the help here!
[Updated on: Wed, 08 September 2004 10:06]
DAMO
MELBOURNE
Re: ignition Wed, 08 September 2004 10:13 Go to previous messageGo to next message
If that igniter accepts like a Square wave 12v input (such as a hall effect switch apposed to magnetic reluctor type), it should work. Email me a pic of the wires coming out of igniter and I'll do a drawing for you. gze@bigpond.com.au
jesseT18
Castle Hill, Sydney
Re: ignition Wed, 08 September 2004 10:25 Go to previous message
http://img76.exs.cx/img76/1306/ignitor.jpg
Previous Topic:1JZ low idle when cold..
Next Topic:can i get this part made?
Current Time: Tue Oct 27 19:13:20 UTC 2026
Total time taken to generate the page: 0.09064793586731 seconds
