Toymods » Tech & Conversions » Speed sensor wiring
Sam99
Speed sensor wiring Wed, 08 September 2004 02:16 Go to next message
I'm doing the 2JZGTE into MA70 swap. Does anyone know if the speed sensor signal from the original R154 gearbox (pink wire on the connector near the ECU) is OK to use as the SP1 input to the 2JZ ECU (pin 11 on the big orange II1 connector from the 2JZ engine wire harness)?
Thanks, Sam
Mos
Toymods IT Secretary
Oz
Re: Speed sensor wiring Wed, 08 September 2004 13:25 Go to previous messageGo to next message
Hi Sam,
The answer is probably, but I'm not sure.
If your MA70 has ABS then it will probably have two speed sensors in the back of the gearbox. If it has ABS and only one speed sensor then I have no idea. If there are two then one will probably be an inductive type sensor (for the ABS) and the second will probably be a mechanical sensor (teeth on output shaft mesh with teeth of sensor) that supplies the cluster and eventually the SP1 input.
If it doesn't have ABS then it probably will only have the mechanical sensor.
(Just rereading your question) You should be able to just use the SP1 input from the orginal 7M ECU. Those engines also have an SP1 (or is it SPD on those ones?) input and there should be no problems using it.
The 2JZ-GTE gearbox in my cressida produces exactly the same SP1/SPD signal as the original 7M box did - they use identical sensors. SP1 and SPD in my experience are the same thing, no matter what engine/gearbox combo...
FWIW they produce 20 pulses per revolution of speed sensor shaft for the cluster, then the cluster usually divides this by 5 to give 4 pulses per sensor revolution for the SP1/SPD input.
HTH.
Mos.
Sam99
Re: Speed sensor wiring Wed, 08 September 2004 23:49 Go to previous message
Thanks Mos,
That's a great help.
Sam
Previous Topic:tinted tail lights
Next Topic:Auto Gauges info please.
Current Time: Sun Oct 25 00:19:44 UTC 2026
Total time taken to generate the page: 0.003838062286377 seconds
