Toymods » Tech & Conversions » putting bigger wheels on a car...
WHITCHY
Castle Hill
putting bigger wheels on a car... Wed, 08 September 2004 06:32 Go to next message
Hey guys, selling the Seca soon, promised a mate I would chuck him the wheels for his AE80, just wondering if there is anything you have to do when changing the wheels to a bigger size (from 13" to 14" or 15" rims), like get the speedo reconfigured? I know he will have to get a wheel alignment but is that all?
Cheers for any info.
-Whitchy-
Stefan
Hobart, Tas
Re: putting bigger wheels on a car... Wed, 08 September 2004 06:47 Go to previous messageGo to next message
That has everything to do with the circumference of the tyre, and has nothing to do with the size of the rims. If you go from 13" to 14"s, but have lower profile rubber on the 14s in order to maintain the same circumference then - no problem.
As for a wheel alignment - I doubt it, unless they are a really different width and you need to change the toe for some reason. Did you mean wheel balance?
EDIT: AE80? If that's a pre AE86 corrolla, then it's rwd. A Seca is fwd... Razz
[Updated on: Wed, 08 September 2004 06:48]
MR 1JZ
Re: putting bigger wheels on a car... Wed, 08 September 2004 06:53 Go to previous messageGo to next message
I thought the PCD was the same on FWD and RWD corollas? Confused
if it is then they will fit but you may need spacers Very Happy
WHITCHY
Castle Hill
Re: putting bigger wheels on a car... Wed, 08 September 2004 06:58 Go to previous messageGo to next message
ah ok then wheel balance is what I meant then I guess!
The wheels I am gonna give him are just stock AE82 Seca rims, with standard tyres, they just look better than the steelies currently on his AE80
(AE80 is just an earlier model corolla with a 1.3 maybe 1.4L engine, opposed to the AE82 that the wheels are coming off which has the 1.6 4A {but both have identical dash boards and instument clusters, only difference being that the AE82 has a clock(AE80 has the hole where the clock should be and it just has a plastic insert instead, and the instrument cluster on the AE80 just has a speedo and an empty spot that says corolla-which is where the tacho is on the AE82}
so can he just put the wheels on and get a wheel balance and thats it, or is there a bit more to it??
Thanks Heaps.
-Whitchy-
Ahhhh Stefan...I can't believe you just called a Sprinter a Corolla! hahahah!! hope no one sees that! hahahaha
[Updated on: Wed, 08 September 2004 07:06]
Stefan
Hobart, Tas
Re: putting bigger wheels on a car... Wed, 08 September 2004 09:23 Go to previous messageGo to next message
WHITCHY wrote on Wed, 08 September 2004 16:58
I hope they do. An AE86 IS a Corolla, and were only called a Sprinter for the Aus market AFAIK.
BTW I hope you understand the concept of offset and the difference between fwd wheels and rwd wheels. There is a bit more to it.
Dodgy_Haro
Re: putting bigger wheels on a car... Wed, 08 September 2004 09:35 Go to previous messageGo to next message
MR 1GGTE wrote on Wed, 08 September 2004 16:53
In general:
FWD - 100 PCD
RWD - 114.3 PCD
ae80
Castle Hill
Re: putting bigger wheels on a car... Wed, 08 September 2004 11:31 Go to previous message
The ae80 is just a lower version of the Ae82. It has a smaller engine ( 1.3 4spd manual )and less accesories..
As for changing the wheels, all that is needed is to make sure that the circumference stays the same, then no adjustment to the speedo will have to be made...
Il talk to you tomorro about it Whitchy
Previous Topic:GZ10 springs
Next Topic:1JZ low idle when cold..
Current Time: Tue Oct 27 07:54:26 UTC 2026
Total time taken to generate the page: 0.050688028335571 seconds
