Toymods » Tech & Conversions » Leaning out problem
Fattony
Leaning out problem Thu, 09 September 2004 07:58 Go to next message
Got a minor problem with the 1ggte which is now running a stock ecu, timming is right but it has just decided that it wants to lean out the fuel mixtures and i have nfi why it is doing it, has any1 else had the same isssue and if you did how did you fix it?
Cheers Adam
Re: Leaning out problem Thu, 09 September 2004 08:27 Go to previous messageGo to next message
First thing I'd look for is air leaks, specifically between the AFM and turbos.
Fattony
Re: Leaning out problem Thu, 09 September 2004 08:32 Go to previous messageGo to next message
Tis all sealed fairly tight, one line that goes to the stepper motor and one to the crankcase venting the rest is just a metal pipe.
Bugman
Re: Leaning out problem Thu, 09 September 2004 10:45 Go to previous messageGo to next message
your just doing this to get it engineered right. then back with the aftermarket.
cant you bodgy the afm to get it a bit richer.
ChuckLandwehr
Re: Leaning out problem Fri, 10 September 2004 06:16 Go to previous messageGo to next message
Adam, check your fuel pump delivery pressure. If you dont have access to a guage, a quick test,is to clamp off your fuel return line, and check AFR.
regards Chuck.
Fattony
Re: Leaning out problem Fri, 10 September 2004 09:19 Go to previous messageGo to next message
I tried making it richer doesnt work, though i did change afms and it did run better but i wasnt allowed to asjust the afm so chances are the spring on mine might be fuggered but it did make a differecne to it when adjustmted though. What does AFR mean?
greenta22
Dandenong Ranges, VIC
Re: Leaning out problem Fri, 10 September 2004 11:41 Go to previous message
Air to Fuel Ratio
Previous Topic:1jz...where do these go?
Next Topic:Ra60 Auto Shifter?
Current Time: Thu Oct 22 07:53:42 UTC 2026
Total time taken to generate the page: 0.0060431957244873 seconds
