Toymods » General Car Talk » car immobilisers
Evil_Foetus
Ballarat, Victoria
car immobilisers Thu, 09 September 2004 10:07 Go to next message
my ma61 has an an aftermarket keyless entry/immobiliser installed on it, before i bought it...
now thats all very good and well, but lately, it's shit itself. the majority of the time, it doesnt work at all (as seen by a dead flashing light on my steering column) but, if i move the circuit board/box thingie (its the immobiliser itself) that hangs near the foot pedals (dodgy) the light will come back on, and i may be able to lock the car. but the locks go crazy, and the light will dier shortly after. sometimes i press the button on the keyless thing and the immobiliser just dies.
i took a lot of the dash apart, looking for bad connections and earths, but everything is okay....
except for the wiring of the damn thing. everything is cut and spliced, with black tape everywhere.
my question is, can i just take the car somewhere and they can put a new keyless entry/immobiliser in it? i want one that goes "bip bip" anyway.
or, has anyone else experienced a similar problem?
thanks for any help guys.
ps. if this belongs in tech, my apologies, and please move it someone Smile
BlackSupra
Re: car immobilisers Thu, 09 September 2004 10:09 Go to previous messageGo to next message
bad earth
pull apart all the tape
PITA, and will take time, but deal with it!
Cyber-punk
Brisbane, QLD
Re: car immobilisers Thu, 09 September 2004 10:14 Go to previous messageGo to next message
i have a stock alarm\keyless entry
its shit Razz
doesnt even control the central locking Sad
might do something about it one day...probably wont
but i'd suggest tracing each wire out of that box to its source, disconnecting it, cut the end of, strip the sheath and reconnect
or just rewire it all which is almost the same as my first suggestion
muaythaiman
Re: car immobilisers Thu, 09 September 2004 10:27 Go to previous messageGo to next message
most likely it is faulty.(the immobiliser) get a new one. they aren't that dear anyway and it would probably cost as much to repair yours. (standard service charge $60app. then if its stuffed you have to get a new one anyway)
p.s. it is unlikely it is the wiring. if it worked b4 and it was installed properly it would have been soldered in. you also already have the actuators in the doors so fitting a new unit isn't hard. can be done in an hour if you know what you're doing
[Updated on: Thu, 09 September 2004 10:29]
sideshow
Re: car immobilisers Thu, 09 September 2004 12:25 Go to previous messageGo to next message
alarms are so fukt these days
no one wants to pay for a good quality alarm and get it fitted properly too
never ever get one of those 1 hr al;arm fitting jobs for say 200 bucks
if u see the mess they make under the dash then u will understand
it might work ok for a long time but if u ever have to diagnose
something under the dash u will know what i mean
to fit an alarm properly its easily 2 to 5 hrs depending what u need doin
i have ripped out so many dodgey alarms and just soldered wires back together due to fauly fukin alarm
they piss me off so much Smile
Evil_Foetus
Ballarat, Victoria
Re: car immobilisers Thu, 09 September 2004 14:47 Go to previous messageGo to next message
thanks guys-
and sideshow- you're right, my wiring is an absolute disgrace, a complete fucking mess. it gave me the shits when i saw it. Mad
but yeah, i think ill do as glen says to start with, check all the earths... then if nothing works, ill get a new one most likely...
whoever installed it fucked up my door lock switch and my hazard lights too, coz neither work. Confused
river
Land of Oz
Re: car immobilisers Thu, 09 September 2004 23:15 Go to previous messageGo to next message
Could be a bad wire or connection somehwere. If it goes on and off and acts wierd when shaken, then it could be traced and fixed.
Hold the unit still and shake a wire at a time. If it's a bad connection, you should get some reaction from the unit. Also, if it's a circuit board, check that it's not cracked.
Are the wires soldered or connected with plugs?
If connected with plugs, pull each plug, put a drop of WD40 on a cotton bud and clean the contacts and the socket.
If soldered, check for poorly solered wires. It's easier to use a magnifying glass and check if the wire looks attached, via solder, or looks like its a bit loose and there's a crack around the wire. Also, solder should be shiny - too satin sort of gleam to it. If its white or matt grey, it can be a poor solder joint.
If so, get a soldering iron and touch a bit of solder onto the the tip and resolder the wire.
And, as mentioned, check that the earth (and power) connections are clean and correct voltage is getting to the unit.
muaythaiman
Re: car immobilisers Fri, 10 September 2004 12:50 Go to previous messageGo to next message
sideshow u r a tool. i fit alarms/immobilisers/stereos for a living. if you take 2 to 5 hours to fit an alarm you are a hack.
muaythaiman
Re: car immobilisers Fri, 10 September 2004 12:53 Go to previous messageGo to next message
ps if you have to diagnose shit you went to the wrong person in the first place!!!!!!!!!!! i can fit an immobiliser in 40 to 50 mins in a post 88 car. so if it takes more than 2 hours for a novice to do it then get someone who knows what there doing to do it.
Re: car immobilisers Fri, 10 September 2004 12:58 Go to previous messageGo to next message
Oh o boys, looks like we have another one Rolling Eyes
muaythaiman
Re: car immobilisers Fri, 10 September 2004 13:09 Go to previous messageGo to next message
take it how u want. but do you realise how many jobs people like me have to fix because novices have tried to fit electronics to their cars themselves then we get the blame because it takes twice as long to pull the shit out of the car because it wasn't fitted properly in the first place>? i wish there was a law against that.
Re: car immobilisers Fri, 10 September 2004 13:12 Go to previous messageGo to next message
How are we supposed to take it? You call one of the respected members and forum sponsors here a fool, then go on to agree with him and insinuate he's a novice for taking so long. Go look at his website and see what he does for a living before you decide to stir shit.
muaythaiman
Re: car immobilisers Fri, 10 September 2004 13:22 Go to previous messageGo to next message
well i wouldn't be advertising the fact dude. it is wiring in general. i only deal in alarms/immobilisers/stereos and hands free phone kits mate, an i dont respect anyone till i see there work. i dont judge someone on their advertisement. i judge someone on their work. the person who advertised probably does more than just fit immobilisers. i am just sick of pulling retards work out of cars because they fucked it up in the first place. if people just spent the extra one hundred dollar then i wouldnt have to fix shit and nothing would fuck up because of faulty installation thats all
Re: car immobilisers Fri, 10 September 2004 13:25 Go to previous messageGo to next message
Fair call on not respecting others work till you've seen it, but respect works both ways and you can't take shots at them without seeing it either. Put it this way, if Sideshow recommends taking time to do something like that, just think of it as installations that don't get fucked up due to dodgy operators trying to save time.
muaythaiman
Re: car immobilisers Fri, 10 September 2004 13:31 Go to previous messageGo to next message
like i said, i didnt take a shot at anyone personally, i just wish that people would go to a an australian standard installer b4 they start to fuck with it themselves
Re: car immobilisers Fri, 10 September 2004 13:33 Go to previous messageGo to next message
muaythaiman wrote on Fri, 10 September 2004 21:31
muaythaiman wrote on Fri, 10 September 2004 20:50
no? Rolling Eyes
muaythaiman
Re: car immobilisers Fri, 10 September 2004 13:34 Go to previous messageGo to next message
people tinker with it themselves then blame people like me or sideshow for it not working. TAKE IT TO THE INSTALLER THEN ASK WHY IT DOESNT WORK. DONT PLAY WITH IT YOURSELF.................IF YOU DID IT TO MY WORK IT WOULD VOID THE MY WARRANTY OF A FAULTY INSTALL.
muaythaiman
Re: car immobilisers Fri, 10 September 2004 13:36 Go to previous messageGo to next message
I WILL GLADLY PULL APART MY OWN INSTALL TO FIND OUT WHETHER THE EQUIPMENT IS FAULTY OR MY WIRING. IF YOU PLAY WITH IT I HAVE BETTER THINGS TO DO. THAN TRY TO FIND OUT WHETHER THEY CHANGED OR FUCKED WITH THE ORIGINAL INSTALL.
stumpy
perth WA
Re: car immobilisers Fri, 10 September 2004 13:40 Go to previous messageGo to next message
No need to shout dude Smile
Jeff
muaythaiman
Re: car immobilisers Fri, 10 September 2004 13:45 Go to previous messageGo to next message
GET A LIFE FRANK I BET SIDESHOW KNOWS I WAS HAVING A DIG AT HIM WITHIN THE BUSINESS AND YOU ARE JUST BALLOONING THE ISSUE BECAUSE YOU ARE A WEAK AND PATHETIC LOSER WHO PROBABLY GETS HIS DAD TO PAY FOR EVERYTHINGON YOUR CAR~!!!!!! WE ALL TEASE EACH OTHER ON THE TIME IT TAKES TO DO A CERTAIN JOB AND IF YOU DON'T DO IT FOR A LIVING YOU SHOULD CLIM BACK UNDER THE ROCK YOU CRAWLED OUT FROM UNDER!!!!!!!!!!!!!!!!!!!!!!!!! SIDESHOW I WOULD BE INTERESTED TO CHAT TO YOU SOMETIME IF YOU WANT IF YOU WANT TO. I CAN GIVE YOU SOME POINTERS ON HOW TO GET THROUGH YOUR JOBS ALOT QUICKER Wink I KNOW JUST ABOUT EVERY FACTORY WIRING HARNESS IN EVERY CAR FOR PHONES AND WELL, IMMOBILISERS AND AND ALARMS, ITS NOT THAT HARD.
Re: car immobilisers Fri, 10 September 2004 13:49 Go to previous messageGo to next message
Haha, don't have a cry. The caps lock button is to the left of your keyboard. What, I didn't respond so you say something to try and get me pissed off?
If "Daddy" had paid for my car, it wouldn't have taken me so long to pay for everything now would it? Dude, to be honest, I don't give a stuff about what you say here, or how good you seem to think you are at what you do, all you've achieved tonight is to show just how well you've assumed your new position as keyboard warrior. Laughing
Lots of kisses,
Nathan xxx Laughing
muaythaiman
Re: car immobilisers Fri, 10 September 2004 13:52 Go to previous messageGo to next message
?????????? keyboard warrior??? you ahve tooooo kuch time on your hands dude
muaythaiman
Re: car immobilisers Fri, 10 September 2004 13:54 Go to previous messageGo to next message
ps. if i wanted to piss you off i wouldnt do it through this communication.
Re: car immobilisers Fri, 10 September 2004 13:55 Go to previous messageGo to next message
What was the point of your reply then dude, there was nothing constructive there you hadn't already said before?
Evil_Foetus
Ballarat, Victoria
Re: car immobilisers Fri, 10 September 2004 14:05 Go to previous messageGo to next message
just to add to information, i haven't tried to fix anything on my immobiliser yet, all ive done is added a constant power source (to my head unit) to a wire i found under the dash
and yes, my immobiliser worked for a good 2 months after i did this, then it died...
anyway, ill have a look at earths one day. then ill probably just take it in. are immobilisers and keyless entry systems expensive?
muaythaiman
Re: car immobilisers Fri, 10 September 2004 14:20 Go to previous messageGo to next message
an imm. and keyless entry aren't exp. no. you already have actuators in the doors. like i said in the first place, should only take an hour to fit a new immobiliser, the door activating hook ups are all ready there. all you have to dois find earth/constant/acc/ign/and crank. (easily done with a test lead)
1983supra
Riverview Sydney
Re: car immobilisers Sat, 11 September 2004 09:30 Go to previous messageGo to next message
Ryley, only just read this thread. The immobiliser was installed by a supposed "professional". I had trouble with the box and took it to the manufacturer as the "professional" has since ceased trading. The manufacturer is Antitheft at College St in Gladesville. He did a test on the box and fixed a blown diode on the spot. I can give you the telepnone number or post it to me I will drop it over to him and post it back.
Evil_Foetus
Ballarat, Victoria
Re: car immobilisers Sun, 12 September 2004 06:39 Go to previous messageGo to next message
hmmm cool thanks wayne
did you experience similar problems to what i'm experiencing?
ive moved it around a bit and it seems to be working again... for the minute....
ill let ya know tho wayne, thanks Very Happy
BradW
Bottom of the hill, Sydney
Re: car immobilisers Mon, 13 September 2004 13:19 Go to previous message
muaythaiman wrote on Fri, 10 September 2004 22:50
Or maybe just someone who can afford to take a little longer to ensure a neat, quality job. Just because he doesn't do it in 40 to 50 minutes doesn't mean he can't. Smile
Brad
Previous Topic:Freight
Next Topic:Will anyone in Perth help do a conversion on my ae86 for cash?
Current Time: Fri Oct 23 04:55:43 UTC 2026
Total time taken to generate the page: 0.12880396842957 seconds
