Toymods » Tech & Conversions » T18 gearbox good for sprinter?
Mark
T18 gearbox good for sprinter? Thu, 09 September 2004 13:13 Go to next message
ive been offered a T18 gearbox. Is this worth holding on to for my sprinter?
pannelvan_screema
Campbelltown, NSW
Re: T18 gearbox good for sprinter? Thu, 09 September 2004 14:46 Go to previous messageGo to next message
I would say no as i am pretty sure the T-18 T50 has ditterent ammount ot splines on the input shaft 20 i think and the AE-71/AE-86 T-50 has a 22spline input shaft.
I am pretty sure about that but would be good if someone could support my story
Henn
Rosanna, Melb
Re: T18 gearbox good for sprinter? Fri, 10 September 2004 01:37 Go to previous messageGo to next message
If the output splines are different you can always use a T18 front tailshaft section too.
I've heard of a few people on here trying it without good results. From memory some work needs to be done on the A bellhousing to get it to fit to the T18 box.
If it is possible then I am very interested.
Hen
CLG
Perth, Western Australia
Re: T18 gearbox good for sprinter? Fri, 10 September 2004 01:49 Go to previous messageGo to next message
Yes it can be used, but I would advise against it. The bearing supports in the A series bellhousings are differnet to the requirements for the box, simply dismissing this fact often sees them leak oil quickly. the output shafts are also different, but this can be solved by using the T18 front shaft as mentioned above. Personally, I'd pay the extra for the AE86/71 box.
TE72_Turbo
Re: T18 gearbox good for sprinter? Fri, 10 September 2004 14:21 Go to previous message
...and the T18 gearbox has a smaller diameter, radial ball bearing to support the input shaft, which is pretty pissweak (have broken several Sad ), whereas the 4AC/AG one has a nice roller bearing which seems to take abuse much better. Smile
Previous Topic:20v?
Next Topic:Stock sprinter + $3000, advice?
Current Time: Fri Oct 23 21:36:52 UTC 2026
Total time taken to generate the page: 0.0051720142364502 seconds
