Toymods » Tech & Conversions » KE55 brake upgrade question(s)...
gr8r-x
Vic, AU
KE55 brake upgrade question(s)... Fri, 10 September 2004 02:11 Go to next message
Hey,
Have read through pretty much every article I've been able to find on the web re: brake upgrades on older model Corolla's and have found lots of useful info.
The main question I have though is in regard to the Hilux/Peugeot/Corona combo upgrade on a Celica article. Can this upgrade be performed on a KE55 Corolla? From what I've read it seems possible, just wondering if anyone else has experience with this?
Mainly I need to know if I'll have to replace steering arms, strut tops, spring holders, etc. Or is it a straight swap over?
Thanks heaps for any help, in advance. Smile
Banjo
Re: KE55 brake upgrade question(s)... Fri, 10 September 2004 02:57 Go to previous messageGo to next message
Hey, Very interested in any answers you get, or what you've found on the web regarding this topic. I have a 1979 KE55 Coupe in good condition, and I'm just going through the process of planning for a complete upgrade in the near future, and a brake upgrade will be an absolute necessity.
You might like to post any sites or URLs where you have found useful information, of comments from others, who have been down this road before.
Let us all know how you make out.
gr8r-x
Vic, AU
Re: KE55 brake upgrade question(s)... Fri, 10 September 2004 03:04 Go to previous messageGo to next message
Mate, I just googled for ke corolla brake upgrade and started reading from the top. Laughing
Most helpful article was definately the one from here though. But it wasn't for a Corolla, hence the question. Smile
Banjo
Re: KE55 brake upgrade question(s)... Fri, 10 September 2004 03:12 Go to previous messageGo to next message
Thanks, I'll start with Google & exchange notes with you if I come across something very interesting.
gr8r-x
Vic, AU
Re: KE55 brake upgrade question(s)... Fri, 10 September 2004 03:21 Go to previous messageGo to next message
71-74 Corolla Modifications, Technical tips and How To's
A bit old (model wise), but good info none-the-less.
http://www.netwiz.net/~tcar/ctechtips.html
The Oldcorollas FAQ
An FAQ dealing with KE1x to KE7x Toyota Corollas
http://www.superjamie.net/oldcorollas/other/conver sions.html
Boneyard Brigade
US site, but still got some good hints.
http://www.grmotorsports.com/boneyard.html
Jonnys Old Corolla Page
Another great page, check out the "Corolla Handling Info" page. Smile
http://www.geocities.com/jonnyr_1973/
Got more at home.
EMP-2TG
Carlingford, Sydney
Re: KE55 brake upgrade question(s)... Fri, 10 September 2004 03:42 Go to previous messageGo to next message
of course it can be done
go look at the link in my sig to see photos Smile
gr8r-x
Vic, AU
Re: KE55 brake upgrade question(s)... Fri, 10 September 2004 06:45 Go to previous messageGo to next message
Great. Now, how? Very Happy
gr8r-x
Vic, AU
Re: KE55 brake upgrade question(s)... Fri, 10 September 2004 10:42 Go to previous messageGo to next message
Yah! Found it. Very Happy
http://www.garagedori.com/tech/rt132_struts_into_k e35.php
Read through that, most handy piece of web I've ever read.
Thanx go to EMP-2TG though, found the link off his site.
gr8r-x
Vic, AU
Re: KE55 brake upgrade question(s)... Sat, 11 September 2004 07:28 Go to previous messageGo to next message
Well I went down to the local 4x4 wreckers (http://www.hall4x4salvage.com.au/), good blokes, had a bit of a chat to them about the whole setup and they were very helpful. Got a price of $250, is that good? Never had to buy them before. Razz
Also had a look through the DBA tech specs on the discs used on the Hilux/Corona/Peugeot's, and I don't see any reason that you would need to file down anything on the caliper.. The inside part, where the rotor goes past, measured about 24mm, with the Peugeot rotor only coming in at a original thickness of 20mm. If you were to get a set of seconds, one would assume they would be a bit down on that. The offsets looked fine as well, only 1mm diff between Corona/Peugeot rotors.
Spose I won't really know until I get all the bits together. Smile
BTW. Anyone got rough prices on what I should expect to pay for all the parts? Thinking I might try and source some 2nd hand rotors first, new if I have to...
Jonny2TG
Tasmania
Re: KE55 brake upgrade question(s)... Sat, 11 September 2004 10:02 Go to previous messageGo to next message
I have a KE55 Corolla, and had done this conversion. (I refer to it as my TE37 now if I may, 2T-G etc)
When using the XT130 Corona struts, you will also need to use the steering knuckles/arms that bolt to them at the bottom. RA23 Celica knuckles are the same. You will have to cut off the spring mounts from both the Corona and Corolla struts. Weld the Corolla spring seats onto the Corona struts. Use the standard Corolla spring top and strut tops.
Or, go to a coilover setup.
Try and use a master cylinder of 15/16". I have a 13/16" which is just ok, 7/8" or 15/16" would be better.
Make sure the brakes you buy come off a vehicle with 20m disks, for the standard hilux/peugeot/corona conversion. Get them from a 4x4 Hilux, the latter ones with vented disks. DOn't get them off a Landcruiser as they are often different. Also beware, some 4runners/Surfs have thicker disks (wider calipers), which would be good to use, but not with the 20mm peugeot disks.
Re: KE55 brake upgrade question(s)... Sat, 11 September 2004 13:31 Go to previous messageGo to next message
Later car I know, but here's an idea:
On my KE70 I'm using R33 turbo rotors (297mm) and calipers (4 pot), hilux drums on the back (too lazy to switch them for anything else; they were on the diff) and a landcruiser master cylinder. Wasn't too hard to do, and works relatively well.
styler
Re: KE55 brake upgrade question(s)... Tue, 15 March 2005 03:09 Go to previous message
[Updated on: Tue, 15 March 2005 03:19]
Previous Topic:KE35 front brake upgrade?
Next Topic:MA70 front on Soarer?
Current Time: Thu Nov 19 16:04:20 UTC 2026
Total time taken to generate the page: 0.007627010345459 seconds
